Старый 28.08.2007, 04:11   #1
Solutions Monkey: Forms Based Authentication ( FBA) in WSS 3.0 / MOSS 2007
Источник: http://blogs.msdn.com/solutions/arch...moss-2007.aspx
1. Configure SharePoint Central Admin
  • Login to SharePoint Central Admin
  • Go to Application Management / Application Security / Authentication Providers and Change the Web Application to the one which needs to be configured for Forms Based Authentication
  • Click zone / default, change authentication type to forms and enter ActiveDirectoryMemebershipProvider under membership provider name ( for example , "ADMembershipProvider") and save this change
2.Update the web.config of SharePoint Central admin site
under node
Ошибка после установки - AX40SP2FP1EE natterru DAX: Администрирование 13 03.09.2010 09:53
Solutions Monkey: EP/Role Centers in WSS vs MOSS Blog bot DAX Blogs 0 29.07.2008 04:09
Solutions Monkey: Installing SQL Reporting Services and MOSS 2007 on the Same port ( default : 80) Blog bot DAX Blogs 0 30.10.2007 05:03
Solutions Monkey: EP Site Templates not appearing under "Custom Tab" in WSS 3.0/MOSS 2007 Blog bot DAX Blogs 0 14.06.2007 03:52
Solutions Monkey: Enterprise Portal on WSS 3.0 – Ax32.exe.config Blog bot DAX Blogs 0 09.01.2007 22:51
Часовой пояс GMT +3, время: 07:53.
