Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 12.12.2007, 23:39   #1
gb is offline
gb
Security keys
Has anybody tried to compare security keys between AX 3 and DAX 4?
Is it documented anywhere?
Thanks,
gb
Старый 17.12.2007, 11:13   #2
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Сообщение от gb Посмотреть сообщение
Has anybody tried to compare security keys between AX 3 and DAX 4? Is it documented anywhere?
What kind of comparision are you asking about? If you want to compare the keys themselves you could export them from AOT and compare the export files. If you want to find out the changes in security keys usage and bindings, that whould reqire building some kind of diagrams based on cross-references and comparing those diagrams... Anyway I haven't seen any documents emphasizing security keys usage/binding changes in DAX 4.
Работа с security keys программно Alks DAX: Программирование 5 05.12.2007 12:34
Inside Dynamics AX 4.0: The Security Framework Blog bot DAX Blogs 0 31.10.2007 11:40
Inside Dynamics AX 4.0: Licensing and Configuration Blog bot DAX Blogs 0 31.10.2007 11:40
Свои Security keys Penguin DAX: Администрирование 3 06.12.2005 12:02
Помогите новичку Security keys listener DAX: Администрирование 4 24.07.2003 16:28
Часовой пояс GMT +3, время: 05:01.
