Старый 23.01.2008, 22:30   #1
axStart: Using your own style sheet information in a weblet
Источник: http://axstart.spaces.live.com/Blog/...C0A0!249.entry
First add the styles to the CCS of AX this is done in the file AXEP_v3 or AXEP. The syntax is not complex.
For a Table change at a line like table.MYthing. For the Row use the tr tag and for the Table Cell use the TD tag
tr.red
     background-color: red;
tr.blue
     background-color: blue;
next redeploy your style sheet and you can use it in your weblet
public void run(Args args = null)
    int rows;
    int columns;
    int currentRow;
    int currentColumn;
    rows = 10;
    columns = 5;
    webSession().writeTxt('');
    for (currentRow = 1 ;currentRow....
axStart: Cannot mix old-style sorting with new-style Group By or Order By on a query. Blog bot DAX Blogs 0 06.11.2008 12:05
axStart: Getting Dynamics AX information into Dynamics CRM, the easy way. Blog bot DAX Blogs 0 15.07.2008 02:13
axStart: InfoPath with default AIF file inbound offline Blog bot DAX Blogs 0 20.05.2008 19:05
axStart: 2. Create HTML content in AX and deploy it with a Weblet Blog bot DAX Blogs 0 23.01.2008 22:30
dynamicsusers: The Style Sheet Tool for Microsoft Dynamics NAV Blog bot DAX Blogs 2 05.07.2007 05:51
Часовой пояс GMT +3, время: 10:36.
