Старый 22.01.2008, 21:33   #1
axaptafreak: Getting new table fields into your form datasource
Источник: http://axaptafreak.blogspot.com/2008...your-form.html
When you create new fields in a table and then go into a form where this table is used, you will not see the new fields in the forms datasource. You could be tempted to go into the properties of the datasource and re-select the table (which would actually add all the new fields).
BUT: Don't do it! You will loose all your modifications and methods made in the datasource !
Better: just exit the Dynamics AX client and enter again. Then, all new fields will appear in your datasource. Helmut Wimmer
Старый 22.01.2008, 23:09   #2
радикально.
думаю, что лучше сначала сохранить и после этого сделать Восстановить у формы.
хотя выйти и зайти тоже сработает.
Старый 24.01.2008, 22:51   #3
axaptafreak: Getting new table fields into your form datasource (part 2)
Источник: http://axaptafreak.blogspot.com/2008...r-form_24.html
After receiving some comments to my previous post (well, in fact it was my intention to get some feedback on it how to do that properly), here is the way to get your new fields of your table to your form's datasource:
after you have added the fields in the table and saved the table, go to the form where the table is used as a datasource, right click on it and select "Restore". After that, you will have your new table fields available in your form's datasource.
A big thanx to denis and jamie for providing me comments on that ! Helmut Wimmer
DeniZone: Invoking a method on a field in a form's datasource Blog bot DAX Blogs 0 13.02.2009 14:05
daxmy: Tips: Enable company/user template when created new form with new table Blog bot DAX Blogs 2 18.10.2007 11:38
Issues concerning X++: Integrating Mappoint into the Customer form... Blog bot DAX Blogs 0 12.07.2007 05:56
PatrickChua: Temporary table Blog bot DAX Blogs 0 28.10.2006 18:14
Часовой пояс GMT +3, время: 06:15.
