#1 |
Вышел Microsoft Dynamics AX 4.0 Service Pack 2 Feature Pack 1 for Eastern Europe
Changes specific to the Russian functionality
Bug ID Knowledge Base ID* Description 26690 940701 Different sales tax amounts in a AR Free text invoice: in Totals inquiry and in a Sales tax form 27299 941759 Adding two lines in the Russian country-specific invoice format according to a local Russian legislative typical inter-industry reporting form 'TOPГ-12' 27636 942475 The system calculates incorrectly the amount in the line of FA Journal for "putting into operations" transaction for models of the account which currency is distinct from base currency. 27969 942431 Using the sales order function ’Update remaining delivery’ ends up with stack trace error 27971 942434 Stack trace error when printing Reimbursement slip/Receipt order from a Packing slip journal 28581 943098 RU- AC& AP\ Contracts\ Payment schedule is not filled in 28812 943572 Purchase book lines does not show adjusted tax amount 30144 944512 Stack trace error occurs when user is going to print Invoice For Payment from AC \ Stack trace error occurs when user is going to print Packing slip with Reimbursement order from AP 30722 945157 Dimensions in the transaction for write off cost item to FA (Db08 Cr 10) is picked up from fin dimensions from FA Posting model 30920 945237 Inventory Error message occurs when Transfer or Requirement slip is printing in case of Officials was tried to change by user 30926 945566 An error message "A section in the report is higher than the actual page size allows" in reports "Customer base data", "Vendor base data" 33240 947842 An error message “Voucher … is already used as of date …” arises when transforming a customer payment to prepayment 33963 948827 Half year straight line life remaining depreciations are not correct in Eastern Europe GLS 34734 950197 Error "Voucher XXX is already used as of date YYY" when two vendor transactions are settled together 34971 949836 RTax25Registers | Non warehoused goods register | Register calculation results do not include some transactions 36529 951572 Act of Adjustment reports shows incorrect zero debit sum in some scenario 37011 951525 Digits' delimiter in the update "Electronic reporting in txt format" 38176 953757 Company address in the Acceptance report (FA-1) if a company Address type is International |
