Старый 26.08.2008, 17:05   #1
axStart: Table caching in AX
Источник: http://axstart.spaces.live.com/Blog/...C0A0!371.entry
There is a lot of misunderstanding about caching of data in AX.
Axapta 3.0 and 4.0 only caches data if you search exactly with the values of the primary index. I will show you with the next example. The primary index on the CustTable is on the field AccountNum.
Example 1 will place the record in my cache. The second example will read from cache. Example 3 and 4 will not do it.
static void cachingTest(Args _args)
    CustTable custTable;
    CustTrans custTrans;
    //example 1*
    select custTable where custTable.AccountNum == "4001";
    info(strfmt("%1",custTable.wasCached())); //not cached
    //example 2
    info(strfmt("%1",custTable.wasCached())); //cached
   //example 3
    select custTable where custTable.AccountNum == "4001" &&
                                              custTable.Name == "The Glass Bulb";
    //example 4
    select custTable where custTable.AccountNum == "4001" join
                custTrans where custTable.AccountNum == custTrans.AccountNum;
* Incase the records was already cached on the AOS cache status is SvrRecordCached
In AX 2009 the caching mechanism has improved. Any unique index will be used for caching optimizing. So let’s repeat the test in AX2009. In the next example (2009), we search 2 times for the same record. The first time we use index PartyID that places the record in the cache the second time we search by accounnum index and will find the result in the cache.
    //example 1*
    select custTable where custTable. PartyId== "215"; //PartyID is also has also an unique index
    //example 2
    select custTable where custTable.AccountNum == "4001"; //same record like partyID == “215”
   //example 3
    //example 4
NOTE: Still there is a primary index property in the AOT, I don’t know why.
axStart: Dynamics AX and Office Business Applications (OBA) Blog bot DAX Blogs 0 27.10.2008 16:05
axStart: Date methods in your Visual Studio Dynamics AX Report. Blog bot DAX Blogs 0 10.09.2008 23:05
Dynamics AX: SQL Tuning: Table & Index Scans Blog bot DAX Blogs 0 20.07.2007 11:50
Часовой пояс GMT +3, время: 23:46.
