Старый 12.11.2008, 22:05   #1
Microsoft Dynamics CRM Team Blog: Data Migration and Import: Using field delimiter characters in the source files
Источник: http://blogs.msdn.com/crm/archive/20...rce-files.aspx
To run data import and data migration, you have to prepare a source file that contains the data you want to import. The data source files must be formatted as comma-separated values (CSV) files. The field values in the source file can be separated by commas, tabs, or other characters that are defined in the importfile.fielddelimitercode property.
Each source file must contain data of one entity type, such as accounts, leads, or competitors.
The first row in the source file should contain column headings. If you do not include the headings, use the importfile.isfirstrowheader property to specify that the first row represents actual data. In this case, default column headings are created with the names Col1, Col2, and so on.
Important:
Do not use any non-printable characters, such as newline (\n) or return (\r) characters, as delimiters for the field values. If you use a non-printable character, you will get a run-time error, such as the following DataColumnsNumberMismatch error:
         80040345      DataColumnsNumberMismatch      The number of fields differs from the number of column headings.   The rows of data that contain non-printable field delimiter characters are not imported.
For a complete list of error codes, see Error Codes.
However, if you want to use non-printable characters as field delimiters in your source data files, you have to install a hotfix.
For more information regarding the hotfix, please refer to the following Knowledge Base article: https://mbs.microsoft.com/knowledgeb...b;en-us;948987.
For more information about how to create and prepare CSV source files for import and data migration, see the Microsoft Dynamics CRM online Help.
Inna Agranov
Microsoft Dynamics CRM Team Blog: Using the Microsoft Dynamics CRM Online Import Wizard Blog bot Dynamics CRM: Blogs 0 08.04.2009 01:06
Microsoft Dynamics CRM Team Blog: Running Data Import: How to Save and Retrieve Parsed Data Blog bot Dynamics CRM: Blogs 0 30.09.2008 01:05
Microsoft Dynamics CRM Team Blog: Data Migration Manager Tips and Tricks Blog bot Dynamics CRM: Blogs 0 02.09.2008 22:05
Import в MS Dynamics CRM 4.0 Сабитов Андрей Dynamics CRM: Функционал 14 07.08.2008 11:42
Microsoft Dynamics CRM Team Blog: Microsoft Dynamics CRM Interviews and Screencasts Blog bot Dynamics CRM: Blogs 0 23.07.2008 03:18
Часовой пояс GMT +3, время: 20:08.
