Старый 20.11.2008, 02:07   #1
Connection from AX to an External Database
Источник: http://alexvoy.blogspot.com/2008/11/...-database.html
There are a few options. We can create an ODBC connection on a local machine or just to connect directly without creating ODBC record.
For exmaple, we want to check whether some records exist in an external table. We should create a OdbcConnection with appropriate LoginProperty and permit to execute a SQL statement by means of SqlStatementExecutePermission class.
server boolean checkExternalDB()
    //connection parameters
        #define.ExternalTableName("CustTable")
        #define.ExternalFieldName("AccountNum")
        #define.ExternalSQLServerName("SRVAXSQL2005")
        #define.ExternalSQLDBName("DAXdb401_Standard_DEV")
        LoginProperty LP = new LoginProperty();
        OdbcConnection myConnection;
        SqlStatementExecutePermission permission;
        Statement myStatement;
        str sqlStmt = "";
        ResultSet myResult;
        boolean ret = true;
        LP.setServer(#ExternalSQLServerName);
        LP.setDatabase(#ExternalSQLDBName);
        try
            myConnection = new OdbcConnection(LP);
        catch
            info("Check connection parameters. "+funcName());
            ret = checkFailed(strfmt("External DB Connection error in: %1"), #ExternalSQLDBName);
        myStatement = myConnection.createStatement();
    //anything you want to get from the external table
        sqlStmt = "SELECT count (RecId) FROM "+#ExternalTableName+ " where "+#ExternalFieldName + " = '" + this.AccountNum+"'";
        permission = new SqlStatementExecutePermission(sqlStmt);
        permission.assert();
        myResult = myStatement.executeQuery(sqlStmt);
        while (MyResult.next())
            if (MyResult.getInt(1) > 0)
                //yes, records exist in the external table
                ret = checkFailed(strfmt("@LBA53"+"\n"+funcName(), strfmt("[%1].[%2].[%3]", #ExternalSQLServerName, #ExternalSQLDBName, #ExternalTableName)));
                break;
        CodeAccessPermission::revertAssert();
        return ret;
msdynamicsax: Upgrading a database from Ax 4.0 SP1 to Ax 2009 Blog bot DAX Blogs 1 13.08.2008 14:02
C# and AX Development: Using ADO for interfacing AX with an external database Blog bot DAX Blogs 0 05.08.2008 05:18
Consuming External Web Services (Dynamics AX 4) Blog bot DAX Blogs 0 19.02.2008 06:41
Часовой пояс GMT +3, время: 22:15.
