Старый 28.01.2009, 12:05   #1
mfp: Dynamics AX 2009 Version Control Interview
Источник: http://blogs.msdn.com/mfp/archive/20...interview.aspx
At Convergence in Copenhagen 2008 Morten Jensen (PM in the MorphX Team) and I were interviewed by Ben Riga on the version control integration in Dynamics AX 2009.
In AX 4 we first introduced version control with integration to SourceSafe. In AX 2009, we introduced Team Foundation Server (TFS) support as well as a MorphX VCS a low –end home-brew version control. I demo the MorphX VCS feature showing how it integrates Check In/Check Out functionality directly into the AX IDE. MorphX VCS is included with Dynamics AX. The target for this low-end VCS is VARs maintaining numerous client system customizations on the same code base.
Version Control is just one leg of the Dynamics AX team’s commitment to Engineering Excellence. They’ve also integrated unit testing and best practices policy enforcement. The Dynamics AX team uses this integration themselves integrating with Source Depot (an internal Microsoft versioning system). They are looking at moving to TFS.
See the full interview and demos at Channel 9.
palleagermark: Channel 9 video: Dynamics AX Version Control interview from Convergence in Copenhagen 2008 Blog bot DAX Blogs 0 30.01.2009 16:05
JOPX: Dynamics AX 2009 - Enterprise Portal link bonanza Blog bot DAX Blogs 0 27.11.2008 01:05
axStart: Microsoft Dynamics AX 2009 White Paper: Team Foundation Server Version Control Setup Blog bot DAX Blogs 0 27.07.2008 13:06
Часовой пояс GMT +3, время: 16:53.
