|  13.10.2009, 19:06 | #1 |
| Участник | CRM Programmer: How to retrieve from many-to-many entity.
			Источник: http://crmpro.blogspot.com/2009/10/h...y-to-many.html ============== If you need to retrieve something from many-to-many relationship entity, and there is no such entity in CRM, then you should use the FetchXml, instead of Query. // Base bodel of FetchXml for get relationship entity string fetchXML = "" + "" + "" + "" + "" + ""; For example, next code snippet is checking a count of relations between the Account entity and New_Industry entity, wich relationship is many-to-many. To achieve this, I need to check the relationship entity - New_industry_account, wich is contains all of relation of our two entities. ICrmService crmService = context.CreateCrmService(true); // check for relation #region FetchXML string fetchXML = "" + "" + "" + ""; #endregion string fetchresult = crmService.Fetch(fetchXML); XmlDocument xmldoc = new XmlDocument(); xmldoc.LoadXml(fetchresult); XmlNodeList xnodlist = xmldoc.SelectNodes("resultset/result"); if (xnodlist.Count > 0) { return; } Источник: http://crmpro.blogspot.com/2009/10/h...y-to-many.html
				__________________ Расскажите о новых и интересных блогах по Microsoft Dynamics, напишите личное сообщение администратору. |
