Старый 24.11.2009, 09:56   #1
spiderone is offline
spiderone
CrmService.Create из java script
и сново я с вопросами.... наковырял вот такой вот кодик в MSDN
// Prepare values for the new contact.
var firstname = "Jesper";
var lastname = "Aaberg";
var donotbulkemail = "true";
var address1_stateorprovince = "MT";
var address1_postalcode = "99999";
var address1_line1 = "23 Market St.";
var address1_city = "Sammamish";
var authenticationHeader = GenerateAuthenticationHeader();
// Prepare the SOAP message.
var xml = "<?xml version='1.0' encoding='utf-8'?>" +
"<soap:Envelope xmlns:soap='http://schemas.xmlsoap.org/soap/envelope/'"+
" xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'"+
" xmlns:xsd='http://www.w3.org/2001/XMLSchema'>"+
authenticationHeader+
"<soap:Body>"+
"<Create xmlns='http://schemas.microsoft.com/crm/2007/WebServices'>"+
"<entity xsi:type='contact'>"+
"<address1_city>"+address1_city+"</address1_city>"+
"<address1_line1>"+address1_line1+"</address1_line1>"+
"<address1_postalcode>"+address1_postalcode+"</address1_postalcode>"+
"<address1_stateorprovince>"+address1_stateorprovince+"</address1_stateorprovince>"+
"<donotbulkemail>"+donotbulkemail+"</donotbulkemail>"+
"<firstname>"+firstname+"</firstname>"+
"<lastname>"+lastname+"</lastname>"+
"</entity>"+
"</Create>"+
"</soap:Body>"+
"</soap:Envelope>";
// Prepare the xmlHttpObject and send the request.
var xHReq = new ActiveXObject("Msxml2.XMLHTTP");
xHReq.Open("POST", "/mscrmservices/2007/CrmService.asmx", false);
xHReq.setRequestHeader("SOAPAction","http://schemas.microsoft.com/crm/2007/WebServices/Create");
xHReq.setRequestHeader("Content-Type", "text/xml; charset=utf-8");
xHReq.setRequestHeader("Content-Length", xml.length);
xHReq.send(xml);
// Capture the result
var resultXml = xHReq.responseXML;
// Check for errors.
var errorCount = resultXml.selectNodes('//error').length;
if (errorCount != 0)
var msg = resultXml.selectSingleNode('//description').nodeTypedValue;
alert(msg);
// Open new contact record if no errors.
else
var contactid = resultXml.selectSingleNode("//CreateResult");
window.open("/sfa/conts/edit.aspx?id={"+contactid.nodeTypedValue+"}");
а вот ссылочка на него http://msdn.microsoft.com/en-us/library/cc677070.aspx
запись в стоке xHReq.Open("POST", "/mscrmservices/2007/CrmService.asmx", false); конечно же менял на свою
смотрел ответ от сервера приходит пустой .... хотя ответ должен быть соответственно ошибка возникает вот тут
в чем может быть дело в самом запросе ?
gustafwesterlund: Create replacement entities Blog bot Dynamics CRM: Blogs 0 18.10.2009 20:05
mscrm4ever: CRM Form Script Loader Blog bot Dynamics CRM: Blogs 0 21.04.2009 04:07
Быстродействие CrmService Bakai Madybaev Dynamics CRM: Разработка 16 21.03.2009 22:57
аутентификация crmService if_maks Dynamics CRM: Разработка 2 25.12.2008 11:52
Обращение к CrmService sergeyjb Dynamics CRM: Разработка 23 05.11.2008 14:22
Часовой пояс GMT +3, время: 12:45.
