Вернуться   AXForum > Microsoft Dynamics AX > DAX: За рубежом > DAX in English
Старый 16.02.2010, 11:28   #1
Damon is offline
Damon
how to Link a Reporting Service report.
i am trying to link a reporting services report i have built in the DAX client.
i see you can create a output menu item, and set it to SQLReportLibraryReport
what i am unsure about is how to add the report to this Report Library,
any help would be greatly appreciated
Damon
Старый 16.02.2010, 17:59   #2
Ivanhoe is offline
Ivanhoe
Аватар для Ivanhoe
4,143 / 2161 (81) +++++++++
You can't build SSRS report in AX client. There are two ways:
1. Report Builder (it's not AX - it's a tool from SQL Reporting Services). Such report can't be linked to AX menu - it can be launced only from Report Manager web-site.
2. Visual Studio. When you've created a Solution, containing a report, you can save it to AOD (there's such an option in Visual Studio with extension of AX-reporting). After doing this and restarting AX, you will find your solution in the Library section of AOT. Afterwards you can point a menu item to your report.
Ivanhoe as is..
Старый 16.02.2010, 23:58   #3
Damon is offline
Damon
sorry typo on my be half, the report was built out of DAX, but i wanted to link the report in the DAX client.
i have found out how to do this via the following site
http://blog.rahulsharma.in/2009/11/o...d-through.html
ax2009, report builder, reporting services, ssrs
emeadaxsupport: How to install AX 4.0 Reporting Role with SSRS 2008 Blog bot DAX Blogs 2 23.01.2010 08:02
emeadaxsupport: Visual Studio Dynamics AX report development how to associate X++ class with report dataSet Blog bot DAX Blogs 0 13.01.2010 23:08
axaptabuilder: How to setup Axapta batch server running as user defined windows service Blog bot DAX Blogs 0 12.04.2007 16:10
Pokluda: Outbound web service (AIF) Blog bot DAX Blogs 0 28.10.2006 17:43
axaptabuilder: How to setup Axapta batch server running as user defined windows service Blog bot DAX Blogs 0 28.10.2006 16:47
Часовой пояс GMT +3, время: 01:29.
