Старый 16.03.2010, 15:05   #1
axaptapedia: Job Template (for running database maintenance script etc)
Источник: http://www.axaptapedia.com/Job_Templ..._script_etc%29
Summary: Use it if you want...
Handy script with some failsafe stuff built into it.
'''I woulnd'nt give users access to it, you still need to know what you are doing.'''
static void _TestJobTemplate(Args _args)
    Dialog      dialog          = new Dialog("Heading of the dialog.");
    Dialog      dlgAreYouSure   = new Dialog("Are you sure?");
    DialogField                 dfAreYouSure;
    DialogField                 dfDryRun;
    str                         sDryRun     = "Dry Run(not modf. data)?";
    str                         sAreYouSure = "Are you sure?";
    str                         sUserAbort  = "User aborted operation.";
    // Setting vars
    boolean                     UseTTS = NoYes::No; // Use tts on (live operation)
    dfDryRun = dialog.addField(typeId(NoYes),sDryRun);
    if (dialog.run())
        // Fetch values from optional dialog fields
        // Check that those values has been submitted
        if(!VAR)
        throw error("You need to supply XY");
        if(dfDryRun.value())
            // Dry Run logic goes here.
        } else {
            dfAreYouSure = dlgAreYouSure.addField(typeId(NoYes),sAreYouSure);
        if(dlgAreYouSure.run())
            if(dfAreYouSure.value())
                if(UseTTS)
                    ttsbegin;
                // Live run logic goes here
                if(UseTTS)
                    ttscommit;
                }  else
                    throw error(sUserAbort);
            } else
emeadaxsupport: Checking Database entries after restoring a Microsoft Dynamics 2009 SQL Database to another Domain or Environment Blog bot DAX Blogs 0 18.02.2010 23:05
axaptapedia: RunBaseBatch Blog bot DAX Blogs 0 04.04.2009 22:05
Microsoft Dynamics CRM Team Blog: Auditing Report Execution using the ReportServer Database Blog bot Dynamics CRM: Blogs 0 19.11.2008 20:05
axaptapedia: Create New AOT Project From Template Blog bot DAX Blogs 0 29.08.2008 21:10
Часовой пояс GMT +3, время: 16:59.
