Старый 21.05.2010, 03:05   #1
emeadaxsupport: AX2009 SecurityProfilerTool
Источник: http://blogs.msdn.com/emeadaxsupport...filertool.aspx
The attached tool tracks what security keys are being used when a user navigates thru the application.
The existing AX class we hook into gets used every time a form or report is opened in AX so the tool will slow performance down – so don’t load this in a production environment.
Also this doesn’t work for menu items that call classes but we don’t expect that to be a big deal.
The tool is useful for sorting out security in a test environment.
In order to use this tool go in as an Administrator that has access to all of the forms and reports in the system:
  1. Import the attached xpo.
  2. Re-launch AX. This step is important because I have added 2 menu items to the Administration menu and they won’t show up until AX is reloaded.
  3. Under Administration go to Security Profiler.
  4. Click the Start Profiling button –and leave this form open.
  5. Navigate to the forms and reports you want to gather security key information about.
  6. Click the Stop Profiling button in the Security Profiler window (the same window opened in step #4).
    a. A form will open showing you all of the security keys that were hit while you navigated thru the system.
    b. To print out the results listed in the report click the Print report button and click the Default button on the print options dialog that opens.
    c. To view your existing security profiles click Administration > Security Profile Results
This tool should not be loaded into a production environment.
emeadaxsupport: Project module Excel pivot table fails with error 0x80070057 E_INVALIDARG Blog bot DAX Blogs 0 10.05.2010 21:05
Shekhar: Dynamics AX2009 : Standalone Installation on Vista with Role centres and workflow. Blog bot DAX Blogs 0 30.03.2010 15:05
emeadaxsupport: How to manually deploy ODC Files to Microsoft Dynamics AX 2009 Enterprise Portal Blog bot DAX Blogs 0 17.02.2010 21:07
emeadaxsupport: Long running process switches from one company to another company Blog bot DAX Blogs 0 27.01.2010 20:05
ax2009 & SSRS kitty DAX: Программирование 6 02.04.2009 10:38
Часовой пояс GMT +3, время: 00:22.
