Старый 30.09.2010, 00:05   #1
Dianne Siebold: Default Location when Saving Attachments in Outlook 2010
Источник: http://blogs.msdn.com/b/dsiebold/arc...look-2010.aspx
If you're an Outlook 2010 user, you've probably noticed that when you save an attachment, it brings up some default file location. Then you have to click through to navigate to the folder where you like to save your files. This was really getting me down and I figured it was one of those small issues that had a solution, so today I finally decided to investigate.
What I found is this KB article entitled How to change the folder where e-mail messages and attachments are saved in Outlook 2003 and in Outlook 2007. The article explains how to add a registry entry so that when you save an attachment, the Save Attachment dialog opens to the default location that you specify. In spite of the title, the process does work with Outlook 2010.
This tip could save you a few seconds each time you save an attachment. I feel my productivity soaring already.
mscrmblog: Setup failed to determine whether a supported version of Microsoft Outlook is installed - Outlook 2010 Blog bot Dynamics CRM: Blogs 0 14.07.2010 07:07
Microsoft Dynamics CRM Team Blog: The Dynamic Duo: Outlook 2010 beta & CRM for Outlook Client Blog bot Dynamics CRM: Blogs 0 08.04.2010 02:13
Muhammad Ali Khan: Relating/Connecting MS CRM 4.0 Data With Custom External Content Type Data In SharePoint 2010 Blog bot Dynamics CRM: Blogs 0 04.02.2010 13:05
Muhammad Ali Khan: Using Business Connectivity Services(BCS) In SharePoint 2010 For Connecting To MS CRM 4.0 Blog bot Dynamics CRM: Blogs 0 25.01.2010 01:08
Muhammad Ali Khan: Business Connectivity Services (BCS) Using WCF & SharePoint Designer 2010 Blog bot Dynamics CRM: Blogs 0 12.01.2010 04:44
Часовой пояс GMT +3, время: 00:25.
