Старый 12.10.2010, 21:05   #1
East Ocean - Technical: Always focus on solutions, not on problems.
Источник: http://eastoceantechnical.blogspot.c...ns-not-on.html
One of the most memorable case studies on Japanese management was the case of the empty soapbox, which happened in one of Japan's biggest cosmetics companies. The company received a complaint that a consumer had bought a soapbox that was empty. Immediately the authorities isolated the problem to the assembly line, which transported all the packaged boxes of soap to the delivery department. For some reason, one soapbox went through the assembly line empty.
Management asked its engineers to solve the problem. Post-haste, the engineers worked hard to devise an X-ray machine with high-resolution monitors manned by two people to watch all the soapboxes that passed through the line to make sure they were not empty. No doubt, they worked hard and they worked fast but they spent a whoopee amount to do so.
But when a rank-and-file employee in a small company was posed with the same problem, he did not get into complications of X-rays, etc., but instead came out with another solution. He bought a strong industrial electric fan and pointed it at the assembly line. He switched the fan on, and as each soapbox passed the fan, it simply blew the empty boxes out of the line.
Lesson learned: Always look for simple solutions,devise the simplest possible solution that solves the problems. Agree?
Старый 13.10.2010, 16:25   #2
Артем Enot Грунин is offline
Артем Enot Грунин
3,912 / 623 (28) +++++++
Записей в блоге: 151
Гений. Я хотел предложить взвешивать
East Ocean - Technical: The path is not of a legal form - Data Migration Manager Blog bot Dynamics CRM: Blogs 0 11.08.2010 11:05
East Ocean - Technical: CRM 4.0 Update Rollup 10 Blog bot Dynamics CRM: Blogs 0 11.04.2010 19:07
East Ocean - Technical: CRM 4.0 Update Rollup 7 Blog bot Dynamics CRM: Blogs 0 26.10.2009 20:05
East Ocean - Technical: CRM 4 - Small changes:big effect Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
East Ocean - Technical: CRM 4.0 Update Rollup 5 Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
Часовой пояс GMT +3, время: 04:31.
