Старый 22.11.2010, 01:11   #1
xplusplus: Warning: Empty compound statement
Источник: http://xplusplus.info/index.php/warn...und-statement/
A compound statement is a part of code usually begins and ends with { and } statements.
Therefore, when facing this warning you have to check whether you forgot some code that you planned to put there later, or you have a logic problem.
This problem can occur in IF statements, try – catch, loops and etc.
best practice, warning, как правильно, компиляция, ошибка компиляции, предупреждение, рекомендации
Leon's CRM Musings: Dynamics CRM Statement of Direction September 2010 Blog bot Dynamics CRM: Blogs 0 03.11.2010 16:05
dynamicsaxtraining: Select statement patterns Blog bot DAX Blogs 10 20.08.2010 14:01
emeadaxsupport: You get the following warning message in BizTalk Server 2006 R2/2009 - The message does not contain a body part (part 2) Blog bot DAX Blogs 0 13.08.2010 00:05
emeadaxsupport: You get a warning message when deploying the AX 2009 smmOpportunityReports report library Blog bot DAX Blogs 0 19.02.2010 05:07
emeadaxsupport: You get the following warning message in BizTalk Server 2006 R2/2009 - The message does not contain a body part Blog bot DAX Blogs 0 18.09.2009 03:13
Часовой пояс GMT +3, время: 19:09.
