Старый 08.12.2010, 20:11   #1
dynamicsaxtraining: Write down the record
Источник: http://www.dynamicsaxtraining.com/kn...own-the-record
To write down the record, which have been just created and does not have modifications use data source method ForceWrite. This method can be used to mark the record as it is changed, and thereby making it a candidate for write, regardless of any changes made to the record. It is valid to call the methods after super in formDataSource::Create(). However, it is not valid in formDataSource::initvalue().
dynamicsaxtraining: How to get original value for table fields during record modification Blog bot DAX Blogs 0 06.12.2010 23:11
dynamicsaxtraining: Item setup: Inventory dimension group Blog bot DAX Blogs 1 05.10.2010 15:35
emeadaxsupport: Error when trying to register the AIF services - "Cannot create a record in Data Policy Schema Information (AifDocumentField)" Blog bot DAX Blogs 0 29.03.2010 21:05
dynamicsaxtraining: Create purchase order Blog bot DAX Blogs 0 14.12.2009 14:05
dynamicsaxtraining: Setup initial data (Vendor, Warehouse, Equipment) Blog bot DAX Blogs 0 07.12.2009 19:05
Часовой пояс GMT +3, время: 12:05.
