Старый 29.12.2010, 18:11   #1
daxdilip: AIF Error creating the Web Proxy specified in the 'system.net/defaultProxy' configuration section.
Источник: http://daxdilip.blogspot.com/2010/12...specified.html
A small tip when you are working on Dynamics AX AIF Services running on VPC
A background - I have a very simple AIF .Net Client App which has been very handy for me to test AIF Services on any environment. This client app consumes the AIF Customer Service to create customer records in AX.
Issue
Recently, when I was trying to generate the proxy for one of the AIF Service which was running on a VPC I ran into this error below (Note the client app project was on my host machine and I was opening the VS project via the shared drive)
"Error creating the Web Proxy specified in the 'system.net/defaultProxy' configuration section."
Solution
Copied the Visual Studio Client App Project into the VPC, Built it and re-generated the proxy for the service and now it works
aif, webservice
Удаленная работа с CRM и расширеный поиск ASheff Dynamics CRM: Разработка 64 04.06.2010 17:44
emeadaxsupport: What changes are required if we change the Business Connector Proxy used by AX 2009 Generated AIF Web services Blog bot DAX Blogs 0 29.03.2010 15:05
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Часовой пояс GMT +3, время: 07:47.
