Старый 31.12.2010, 11:40   #1
In this blog is described a very simple usage of the .NET interoperability feature with Microsoft Dynamics NAV 2009 R2 and can be considered an extension of my previous blog: http://blogs.msdn.com/b/nav/archive/...nt-add-in.aspx.
It is intended just to familiarize you with this brand new feature proposed with the NAV 2009 R2 release.
If you want to know more about .NET interoperability for NAV 2009 R2, please refer to MSDN link:
Extending Microsoft Dynamics NAV Using Microsoft .NET Framework Interoperability
http://msdn.microsoft.com/en-us/library/gg502499.aspx
The .NET interoperability code snippet in this blog is based on the System.Speech namespace.
http://msdn.microsoft.com/en-us/libr...(v=VS.90).aspx
My ingredients:
  • NAV 2009 R2
  • Windows 7 Enterprise
Create your "Speak it!" action and let NAV speak Customer Names :
1. Open Classic Client
2. Go to the Object Designer
3. Select Page object (alt+g)
4. Select Page 22 "Customer List"
5. Design Page 22 "Customer List" (alt+d)
6. Select View > Page Actions (al+v, o)
7. Create a new Action (F3) in the ActionItems container (see below)
8. Change the properties of the Action as below:
Caption - Speak it !
Image - ViewComments
Promoted - Yes
PromotedCategory - Process
PromotedIsBig - Yes
9. Edit the code in the Speak it! Action (F9)
10. Add those LOCAL variables
dnSpeech
DataType: DotNet
Subtype: System.Speech, Version=3.0.0.0, Culture=neutral,PublicKeyToken=31bf3856ad364e35.System.Speech.Synthesis.SpeechSynthesizer
RUNONCLIENT: YesSynthDataType: DotNet
RUNONCLIENT: Yes
dnVoiceGender
DataType: DotNet
Subtype: System.Speech, Version=3.0.0.0, Culture=neutral,PublicKeyToken=31bf3856ad364e35.System.Speech.Synthesis.VoiceGender
RUNONCLIENT: Yes
I
DataType: Integer
NOTE: RUNONCLIENT is a property of each DotNet variable (shift+f4)
11. Add this code snippet in the OnAction trigger
// Copyright © Microsoft Corporation. All Rights Reserved.
// This code released under the terms of the
// Microsoft Public License (MS-PL, http://opensource.org/licenses/ms-pl.html.)
// Use the constructor to create a new Synthesizer
Synth := dnSpeech.SpeechSynthesizer();
// http://msdn.microsoft.com/en-us/library/system.speech.synthesis.voicegender(VS.90).aspx
// This is an enumeration assignment:
// 0=NotSet,1=Male,2=Female,3=Netural
dnVoiceGender := 2; //Female
// NOTE: it will take the voice depending on what is
// installed locally (e.g. Windows 7 has Microsoft Anne voice)
Synth.SelectVoiceByHints(dnVoiceGender);
// Please, speak slowly (range [-10:10])
Synth.Rate := -3;
Synth.SetOutputToDefaultAudioDevice();
Synth.Speak(FORMAT(Name));
// Row below is not needed. Synth is a local variable therefore it will be
// automatically disposed
// Synth.Dispose;
12. Save and compile (ctrl+s) page 22 "Customer List"
Now... you are ready to let NAV speech the Customer Name from the customer list by simply click on the "Speak it!" action.
Best Regards,
Duilio Tacconi (dtacconi)
Microsoft Dynamics Italy
Источник: http://feedproxy.google.com/~r/Micro...v-2009-r2.aspx
Часовой пояс GMT +3, время: 18:23.
