Старый 28.01.2011, 23:14   #1
axzaptech: Exceptions Inside Transactions
Источник: http://axzaptech.wordpress.com/2011/...-transactions/
When an exception is thrown inside a transaction, the transaction is automatically aborted (a ttsabort operation occurs). This applies both for exceptions thrown manually and for exceptions thrown by the system.
If an exception is thrown inside a ttsBegin/ttsCommit block, it will be caught by the first matching catchlist that is outside the transaction block. If there is a catch block within the ttsBegin/ttsCommit, it will be ignored
Example
Example  shows how an exception in a ttsBegin/ttsCommit block is caught by the first catchlist outside the block rather than by the catch within the ttsBegin/ttsCommit block. If you run this code, “outside tts” will be printed before an Infolog displays “Message”.
 try
  ttsbegin;
  try
  throw error();
  catch
  print not ;
  pause;
  ttscommit;
 catch
  print outside ;
  pause;
Source: http://msdn.microsoft.com/en-us/libr...85(AX.10).aspx
Issues concerning X++: Exception handling and transactions Blog bot DAX Blogs 1 14.02.2009 00:46
Holzheys: X++ Transactions, exceptions and updateconflicts. Blog bot DAX Blogs 2 10.10.2008 01:23
staticsax: New approach to Exceptions and Transactions handling Blog bot DAX Blogs 0 13.11.2007 20:30
Inside Dynamics AX 4.0: Transaction Semantics Blog bot DAX Blogs 0 31.10.2007 23:40
Inside Dynamics AX 4.0: Working with the .NET Business Connector Blog bot DAX Blogs 0 04.10.2007 05:15
Часовой пояс GMT +3, время: 13:15.
