#1 |
kamalblogs: Creating Edit methods for DS that don’t allow editing in Dynamics ax – Followup
Источник: http://kamalblogs.wordpress.com/2011...s-ax-followup/
============== A while ago i made a post on allowing a edit method to work on a disabled datasource .. http://bit.ly/hZMBIW I found a still better idea from one of the comments, this post is to highlight the comment. I rather would loop trough all data source fields (FormDataObject) and set them allowEdit=false at initalization time of the form/ds. That’s more confortable for the user, because he sees, that he cannot modify other fields than the edit fields. - Luegisdorf One suggestion that i would add along to this is creating a SysHelper class for this, in case you find this recurring. You can just pass the record or datasource and the method will disable all the fields. public class SysDictTable extends DictTable implements SysDictXmlReflectionProvider, SysDictXmlDocumentationProvider { public static void disableDSfields(FormDataSource _fds) { SysDictTable dictTable; int i; ; dictTable = new SysDictTable(_fds.table()); for (i = 1; i
