Старый 22.04.2011, 04:14   #1
dax-lessons: Sort a container [using X++ , Dynamics AX]
Источник: http://dynamicsaxgyan.wordpress.com/...x-dynamics-ax/
Friends, Recently I was in need of sorting the elements in the container and use them . I am not sure how far this code is helpful to you guys. Below code will help to sort the elements in the … Continue reading →
static void SR_sortContainer(Args _args)
    container con = [5,1,2,'Sumit Loya',9, 'Ashish singh', NoYes::No];
    str temp1;
    str temp2;
    int i;
    int j;
    container sorCon;
    sorCon = con;
    // Sort the container
    for (i = 1; i <= conlen(sorCon); i++)
        for (j = i + 1; j <= conlen(sorCon); j++)
            temp1 = conpeek(sorCon, j);
            temp2 = conpeek(sorCon, i);
            if (temp1 < temp2)
                sorCon = condel(sorCon, j, 1);
                sorCon = conins(sorCon, j, temp2);
                sorCon = condel(sorCon, i, 1);
                sorCon = conins(sorCon, i, temp1);
    conview(sorCon);
Последний раз редактировалось Poleax; 22.04.2011 в 10:45.
dax-lessons: Container to selectMultiple List using X++ [Dynamics AX] Blog bot DAX Blogs 0 07.04.2011 19:11
dynamics-ax: Official Details about Dynamics AX '6' released, including comments from Microsofts Kees Hertogh Blog bot DAX Blogs 0 11.01.2011 05:22
Часовой пояс GMT +3, время: 08:17.
