Старый 23.04.2011, 07:11   #1
axdaily: X++ attributes
Источник: http://axdaily.blogspot.com/2011/04/x-attributes.html
AX 2012 supports attributes for classes and methods. There are quite a lot of attributes provided out of the box, mostly in AIF, Services, Upgrade, SysTest areas and it is also possible to create new attributes by inheriting from the SysAttribute class.
Attributes can really simplify many frameworks. For example, in the upgrade framework initPreSyncJobs() and initPostSyncJobs() methods, that contained usually quite a large amount of upgrade jobs and dependencies registration code, were effectively deprecated. All the registration is performed now via attributes that are attached to upgrade methods.
Microsoft Dynamics CRM Team Blog: Marketing Lists – Newly Discovered Attributes Blog bot Dynamics CRM: Blogs 0 28.12.2009 21:05
Microsoft Dynamics CRM Team Blog: A Plethora of Phone Attributes Blog bot Dynamics CRM: Blogs 0 09.09.2009 23:07
Afna CRM: Get a list of searchable attributes from database Blog bot Dynamics CRM: Blogs 1 29.08.2009 11:46
East Ocean - Technical: Maximum attributes supported by CRM 4! Blog bot Dynamics CRM: Blogs 0 13.08.2009 15:05
Microsoft Dynamics CRM Team Blog: Just do it – Deleting attributes that are in use by running Workflows Blog bot Dynamics CRM: Blogs 0 31.12.2008 00:08
Часовой пояс GMT +3, время: 18:40.
