Старый 12.05.2011, 15:11   #1
emeadaxsupport: Using AXC file for AX client.
Источник: http://blogs.msdn.com/b/emeadaxsuppo...ax-client.aspx
If you use a AXC file to lunch AX client application be sure to put a single empty line on the end of file. Text on the last line (without ‘enter’ on the end) is ignored.
--author: Karel Fischl --editor: Karel Fischl --date: 12/May/2011
emeadaxsupport: Running AX 2009 Client raises error: "An invalid directory structure for Microsoft Dynamics AX was detected" Blog bot DAX Blogs 0 01.04.2011 06:13
emeadaxsupport: You get a Script Error when viewing Role Centers (deployed on SharePoint 2010) in a Microsoft Dynamics AX 2009 Client Blog bot DAX Blogs 0 04.01.2011 20:11
Microsoft Dynamics CRM Team Blog: Importing two or more entities from a Single File Blog bot Dynamics CRM: Blogs 0 09.11.2010 19:05
emeadaxsupport: Identical AX 2009 AUC File Created For Multiple AX Installations Blog bot DAX Blogs 0 25.01.2010 16:05
Часовой пояс GMT +3, время: 22:00.
