Старый 09.06.2011, 14:37   #1
Hi all,
if you need more information if you getting an error during synchronization enable the Trace log.
  • Browse to %INSTALLDIRCONNECTOR%
  • Edit Microsoft.Dynamics.Integration.Service.exe.config
  • Edit  <add name="Microsoft.Dynamics.Integration.TraceLog" value="0" /> and change it to 4 (<!-- 0-off, 1-error, 2-warn, 3-info, 4-verbose –>)
  • Restart the NAV Connector (shouldn’t be – my experience is “do it”…
  • Browse to %ALLUSERSPROFILE%Application DataMicrosoft DynamicsMicrosoft Dynamics Adapter Logs
    Example: Cocuments and SettingsAll UsersApplication DataMicrosoft DynamicsMicrosoft
    Dynamics AdapterLogs
    or
    %ALLUSERSPROFILE%Microsoft DynamicsMicrosoft Dynamics AdapterLogs
    Example: C:ProgramDataMicrosoft DynamicsMicrosoft Dynamics Adapter
  • Go to the bottom of the file
  • Start Find by Ctrl + F – Options “Up”- Term: Error
Now you can see the last error which occurs. Not always this is the right one you are looking for – so just go forward by using the Find feature.
The trace log usually give you more detail information about the exception.
Note: Also take a look into the event viewer. There you will find error information too.
Regards,
Rene
Далее
Часовой пояс GMT +3, время: 15:57.
