Старый 07.11.2012, 03:24   #1
mfp: Dynamics AX 2012 R2 achieves "Compatible with Windows 8" certification.
Источник: http://blogs.msdn.com/b/mfp/archive/...ification.aspx
Microsoft Dynamics AX 2012 R2 has successfully passed compatibility testing and has achieved the “Compatible with Windows 8” certification.
The Compatible with Windows 8 certification means that the product has passed Microsoft testing criteria for compatibility with Windows 8. The Microsoft Windows Compatibility and Certification program defines a set of compatibility test cases that must be completed successfully-covering areas of Compatibility & Resiliency, Adhere to Windows Security Best Practices, Support Windows Security Features, Adhere to System Restart Manager Messages and perform a Clean, Reversible Installation. The testing is performed using Microsoft’s automated Application Certification framework and tools.
Microsoft Dynamics AX 2012 R2 is now listed among the products that have been certified on the Microsoft Windows compatibility center site.
mfp: Pre-order Inside Microsoft Dynamics AX 2012 Blog bot DAX Blogs 8 27.11.2012 11:46
Dynamics AX Sustained Engineering: Announcing Compatibility Certification of SQL Server 2008 R2 SP1 with Dynamics AX Blog bot DAX Blogs 0 15.12.2011 07:12
dynamics-ax: Modeling the world, with Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 25.01.2011 09:11
Dynamics AX Sustained Engineering: Microsoft Dynamics AX 4.0 and AX 2009 are compatible with Microsoft Windows 7 and Microsoft Windows Server 2008 R2 Blog bot DAX Blogs 0 22.09.2009 04:06
Часовой пояс GMT +3, время: 04:09.
