Старый 04.02.2013, 02:11   #1
Axilicious:System.Diagnostics.StopWatch
Источник: http://www.ksaelen.be/wordpresses/dy...ics-stopwatch/
I often see code that still uses the WinApi::GetTickCount method to measure an interval of time. And though there is nothing wrong with it, I wanted to show an alternative method : the StopWatch already known in .Net for quite some time.
The sample below show the usage of the stopwatch while I was testing something out with looping all of the tables in the system:
static void FetchTableNames_ModelElementTables(Args _args)
    SysModelElement element;
    SysModelElementType elementType;
    System.Collections.ArrayList tableNames = new System.Collections.ArrayList();
    System.Diagnostics.Stopwatch stopWatch = new System.Diagnostics.Stopwatch();
    int64 elapsed;
    stopWatch.Start();
    // The SysModelElementType table contains the element types and we need the recId for the next selection
    select firstonly RecId
    from elementType
    where elementType.Name == 'Table';
    // With the recId of the table element type, select all of the elements with that type (hence, select all of the tables)
    while select Name
    from element
    where element.ElementType == elementType.RecId
        tableNames.Add(element.Name);
    stopWatch.Stop();
    // Get the time it took
    elapsed = stopWatch.get_ElapsedMilliseconds();
    info(strFmt("Time taken: %1", elapsed));
Последний раз редактировалось Poleax; 04.02.2013 в 09:29.
Trace Parser. Error: Incorrect or missing MOF file, import is not available. Poleax DAX: Администрирование 6 13.05.2011 10:43
Удаленная работа с CRM и расширеный поиск ASheff Dynamics CRM: Разработка 64 04.06.2010 17:44
Ошибка бизнес-процесса Tarasov E Dynamics CRM: Разработка 9 18.02.2010 14:02
Не публикуется бизнес-процес Soulcar Dynamics CRM: Администрирование 6 04.02.2010 19:35
Проблема с установкои Email Router на CRM 4 Kosta100 Dynamics CRM: Администрирование 1 22.02.2009 14:00
Часовой пояс GMT +3, время: 06:03.
