Старый 01.05.2013, 03:53   #1
emeadaxsupport: Check out the new Dynamics AX server blog
Источник: http://blogs.msdn.com/b/axsupport/ar...rver-blog.aspx
The Dynamics AX server team has a new blog!
In this blog, members from the Dynamics AX server team will be posting tips and tricks, insights into the product, answer frequently asked questions and in general get a communication with consumers of the Dynamics AX product.
When we talk of the Server team, this covers many areas. Some of which that come to mind are:
  • AOS (Application Object Server)
  • Security Framework
  • Licensing
  • Metadata
  • Data access stack
  • Organizational Model framework
  • Batch processing
Check them out:
http://blogs.msdn.com/b/daxserver/ar...rver-blog.aspx
emeadaxsupport: Dynamics AX 2012 Prerequisite Check Utility and SQL Server cluster Blog bot DAX Blogs 0 20.03.2012 19:11
emeadaxsupport: Unable to install Dynamics AX 2009 Analysis extensions when the default SQL Server Analysis Server collation is set to Turkish_CI_AS or Turkish_CS_AS Blog bot DAX Blogs 0 22.09.2009 04:06
Developer for Microsoft Dynamics AX Certification Roadmap Blog bot DAX Blogs 1 13.05.2009 16:17
Часовой пояс GMT +3, время: 17:39.
