Старый 21.08.2013, 10:11   #1
emeadaxsupport: Forms not opening.
Источник: http://blogs.msdn.com/b/axsupport/ar...t-opening.aspx
In support we have seen a number of cases described along the lines of “Forms opens on remote desktop client but not on local AX client.”
Or “Dialog boxes fail to open.“ Historically we have found that the forms that fail to open are not out of the box forms. Instead they are USR or ISV layer objects.
What we have found is that the “Slide open combo boxes” under Performance options needs to be checked.
On server operating systems this is not turned on by default.
You can find this setting by right clicking on Computer -> Properties -> Advanced system settings -> Performance -> Settings.
emeadaxsupport: Opening a Report on AX 2012 raises infolog error: The default Report Server Configuration ID could not be found in the SRSServers table. Blog bot DAX Blogs 0 02.12.2011 00:13
emeadaxsupport: Unable to validate workflow URL in AX 2009 - Get the following error: The request failed with HTTP status 405: Method Not Allowed Blog bot DAX Blogs 0 07.07.2010 23:05
emeadaxsupport: Error message “The value ‘xxx’ is not found in the map” when opening Workflow configuration Blog bot DAX Blogs 0 10.02.2010 00:07
emeadaxsupport: Warning when loading license file - License value for ID 2024 has not been created (or License value for ID 2025 has not been created) Blog bot DAX Blogs 0 12.01.2010 04:44
emeadaxsupport: AxUpdatePortal.exe does not update Enterprise Portal when not running from an elevated command prompt Blog bot DAX Blogs 0 26.07.2009 15:07
Часовой пояс GMT +3, время: 16:44.
