Старый 21.08.2013, 17:11   #1
palleagermark: Bug in Data Import Export Framework (DIEF) when adding entity for InventParameters
Источник: http://www.agermark.com/2013/08/bug-...framework.html
When using the wizard to generate an entity for InventParameters, the generation fails with the name DEL_InventSumDateFinancialDimensionFocus_RU being too long (more than 40 characters).
The bug seems to come from the \Classes\DMFGenerateEntityTable\modifyFields method. Code from line 142:
                            if(fieldDeleted)
                                treeNodeToDelete = treeNode;
                            else
                                treeNode.AOTRename(#Del + fieldName);
                                treeNode.AOTsave();
The treeNode.AOTRename method is called without checking the length for #Del + fieldName.
dynamicscare: Data Import/Export Framework: Steps for a simple file import Blog bot DAX Blogs 0 22.07.2013 21:12
dynamics-coe: Dynamics AX Export/Import Framework for Vendor balance migration Blog bot DAX Blogs 0 22.05.2013 20:13
axsa: Microsoft Dynamics AX 2012 Data Import/Export Framework (Old name - Data Migration Framework) is now available on Information source Blog bot DAX Blogs 0 16.03.2013 15:12
Microsoft Dynamics CRM Team Blog: Create Sample Data for your Solution Blog bot Dynamics CRM: Blogs 0 01.12.2011 05:14
Часовой пояс GMT +3, время: 04:25.
