Старый 20.09.2013, 19:11   #1
emeadaxsupport: Error 'The value in field offset account is not valid' creating bridged transactions- AX2012 R2 CU6
Источник: http://blogs.msdn.com/b/axsupport/ar...12-r2-cu6.aspx
The issue is in AX2012 R2+CU6- the error message received 'The value in field offset account is not valid' when in General journal we use a function 'Select bridged transactions'.
To avoid an error, you can:
1. Check Journal Name setup in General ledger. If you have set fixed offset account, just remove it (the error appears if we have different fixed Offset account in Journal Name and in Method of payment of bridged transaction).
2. Or in GL Journal Name setup form, you can set fixed Offset account the same as in Method of payment (which was used posting bridged transaction- vendor payment).
emeadaxsupport: Missing SYP labels after upgrading to AX2012 R2 CU6 Blog bot DAX Blogs 0 12.07.2013 20:13
dynamicsaxtraining: Vendor returns Blog bot DAX Blogs 0 11.10.2012 00:11
emeadaxsupport: Microsoft Dynamics AX 2012 Retail Statement Posting Error: Account number for transaction type Ledger journal does not exist Blog bot DAX Blogs 0 27.09.2012 20:13
CRM DE LA CREME! Some more useful javascripts for MS CRM Blog bot Dynamics CRM: Blogs 0 04.05.2010 11:05
Часовой пояс GMT +3, время: 07:01.
