Старый 23.09.2013, 23:11   #1
mfp: X++ Debugging Tips and Tricks #1 – Breakpoint in Info.add()
Источник: http://blogs.msdn.com/b/mfp/archive/...-info-add.aspx
This trick is probably the first every X++ developer learns, so it deserves to be the first on the list of X++ Debugging Tips and Tricks.
Suppose an X++ exception occurs and you want to know why. The error is written to the Infolog. Double-clicking the line in the Infolog window will bring you to the line that threw the exception. Sometimes it is trivial to see the cause just by looking at the code. Other times it is not, and you will need the entire context including the call stack and variables to figure out what the cause is.
Set a breakpoint in the add method on the Info class – and rerun the scenario. When the exception is thrown your breakpoint is hit, and you can perform the autopsy.
This post is provided AS-IS, and confers no rights or warranties.
mfp: X++ Debugging Tips and Tricks Blog bot DAX Blogs 2 24.09.2013 13:01
Microsoft Dynamics CRM Team Blog: Tips and Tricks in Microsoft Dynamics CRM 2011 Dialogs-Part I Blog bot Dynamics CRM: Blogs 0 18.01.2012 04:34
sumitax: EP Debugging Tips and Tricks –Part III Blog bot DAX Blogs 0 13.10.2010 14:05
sumitax: EP Debugging Tips and Tricks –Part II Blog bot DAX Blogs 0 30.09.2010 09:05
sumitax: EP Debugging Tips and Tricks –Part I Blog bot DAX Blogs 0 13.08.2010 21:06
Часовой пояс GMT +3, время: 00:45.
