Старый 20.02.2015, 19:14   #1
dynamics-coe: Outbound HTTP adapter for AIF in Dynamics AX 2012
Источник: http://blogs.msdn.com/b/dynamics-coe...r-for-aif.aspx
There are lots of inbound integration adapters in AX2012 R3, including the File System, TCP, HTTP, Azure Service Bus and MSMQ, but just 2 outbound ones: File System and MSMQ. Both of them are asynchronous only and slow due to disc operations, very bad indeed in our brave cloud world.
Let me close this gap and introduce a small HTTP adapter written in X++, which uses the .NET HttpWebRequest API.
The core method is just 66 lines long:
public void sendMessage(AifGatewayMessage gatewayMessage)
System.Net.HttpWebRequest httpWebRequest;
System.Net.HttpWebResponse httpWebResponse;
System.IO.Stream requestStream,
messageStream,
responseStream;
System.IO.StreamReader responseStreamReader;
System.Byte[] byteArray;
System.Text.Encoding encoding;
int msgLength;
str response;
if (! adapterIntialized)
throw error("@SYS95134");
httpWebRequest = System.Net.WebRequest::Create(transportAddress) as System.Net.HttpWebRequest;
try
if (gatewayMessage.parmMessageStream() != null)
messageStream = gatewayMessage.parmMessageStream();
messageStream.Read(byteArray, 0, int642int(messageStream.get_Length()));
else
encoding = System.Text.Encoding::GetEncoding(gatewayMessage.parmEncoding());
byteArray = encoding.GetBytes(gatewayMessage.parmMessageXml());
msgLength = byteArray.get_Length();
// Set HttpWebRequest properties
httpWebRequest.set_Method("POST");
httpWebRequest.set_ContentLength(msgLength);
httpWebRequest.set_ContentType(strFmt("text/xml; charset=%1", gatewayMessage.parmEncoding()));
requestStream = httpWebRequest.GetRequestStream();
// Writes a sequence of bytes to the current stream
requestStream.Write(byteArray, 0, msgLength);
// Close stream
requestStream.Close();
// Sends the HttpWebRequest, and waits for a response.
httpWebResponse = httpWebRequest.GetResponse();
if (httpWebResponse.get_StatusCode() == System.Net.HttpStatusCode::OK)
// Get response stream into StreamReader
responseStream = httpWebResponse.GetResponseStream();
responseStreamReader = new System.IO.StreamReader(responseStream);
response = responseStreamReader.ReadToEnd();
httpWebResponse.Close();
catch (Exception::CLRError)
messageId = gatewayMessage.parmMessageId(); // to re-send if needed
throw error(strfmt("The HTTP adapter is unable to transmit the message to %1. Error: %2", transportAddress, AifUtil::getClrErrorMessage()));
} Attached you may find an XPO file with the source code, as well as a tiny runtime listener in C# and a simple test routine to play with.
Старый 21.02.2015, 18:34   #2
Vadik is offline
Vadik
Аватар для Vadik
3,631 / 1853 (69) ++++++++
Перенес в Базу знаний
-ТСЯ или -ТЬСЯ ?
Старый 24.02.2015, 10:28   #3
Alex_KD is offline
Alex_KD
AxAssist
522 / 362 (14) ++++++
Не проще ли создать VS проект, подключить Service Reference к внешнему WCF и дергать любые веб методы из X++? Или я чтото пропустил ....
Старый 24.02.2015, 10:42   #4
gl00mie is offline
gl00mie
3,684 / 5813 (201) ++++++++++
Сравните "создать в VS... подключить... дергать в Х++" vs "дать возможность настраивать администратору Аксапты"
Старый 26.02.2015, 10:18   #5
Vadik is offline
Vadik
Аватар для Vadik
Не забываем про удобство поддержки этой этажерки - задеплоить изменения кода из DEV в TEST, поправить VS проект, перебить \ обновить ссылки, то же при переносе в продуктив.. Ммм.. Когда у тебя таких кадавров с десяток и более, разрабатывает несколько человек и часто деплоишь не свои творения - мечта да и только
В песочнице на коленке - безусловно проще, в промышленной эксплуатации в конечном итоге головняк, геморрой и седые волосы на попе
-ТСЯ или -ТЬСЯ ?
Старый 26.02.2015, 10:57   #6
belugin is offline
belugin
Аватар для belugin
4,622 / 2925 (107) +++++++++
Записей в блоге: 5
VS проекты в Ax2012 можно переносить в модельных файлах.
Старый 26.02.2015, 11:30   #7
Vadik is offline
Vadik
Аватар для Vadik
С этим никто и не спорил. Вот только ссылки на сервисы сами (DEV на TEST, TEST на PROD) во время переноса не поменяются. Поэтому и хочется чтобы они (references) не были прошиты в AOT и соответственно не перезжали при переносе объектов, а были частью конфигурации. Собственно этим адаптер и удобен. Вообще непонятно как и в чью светлую голову могла прийти мысль выпилить стандартный outbound http адаптер имевшийся (и работающий) в старых версиях
-ТСЯ или -ТЬСЯ ?
Старый 26.02.2015, 11:40   #8
belugin is offline
belugin
Аватар для belugin
Записей в блоге: 5
А как решается эта проблема в стандартном C#? App.config?
Старый 26.02.2015, 11:54   #9
Vadik is offline
Vadik
Аватар для Vadik
Chester: Okay, Ted, do you know how long it takes the average American to count to 600?
Ted the Bellhop: [Thinks for a bit]
Angela: It's a rhetorical question, Ted.
Ted the Bellhop: No, sir.
Вот хотел же сразу написать что не надо про app.config Ок, перед тем как продолжить давайте определимся с предметом спора - о "стандартном C#" вообще или об AX и AIF. Да, можно нагородить свою "прослойку" между AX и внешним приложением со своей конфигурацией, трансформациями, логами, блэкджеком и прочим, но мне как человеку поработавшему на обеих сторонах баррикад (разработка и обслуживание продуктива) вариант Евгения (вся конфигурация в одной форме портов AIF) как-то ближе и роднее, если сравнивать с кучей конфигурационных файлов хитрым образом разбросанных по нескольким серверам
-ТСЯ или -ТЬСЯ ?
За это сообщение автора поблагодарили: belugin (3).
Старый 26.02.2015, 18:14   #10
Omeo is offline
Omeo
129 / 50 (2) ++++
к сожалению, пока есть проблемы даже со стандартом AIF (типа этой https://community.dynamics.com/ax/f/...18/343522.aspx) с которыми никто в разумные сроки не поможет, приходится придумывать велик
Старый 11.03.2015, 12:12   #11
Vadik is offline
Vadik
Аватар для Vadik
Кстати, теперь (начиная с CU8) c Reference должно стать чуть полегче
KB2998611 - No API is available for dynamically changing the target of a web service reference
-ТСЯ или -ТЬСЯ ?
aif, ax2012
DAX: How to gain additional value from the Microsoft application platform with Microsoft Dynamics AX 2012 R2 Blog bot DAX Blogs 3 21.06.2013 15:16
Sample Design Patterns: Book Give-away: 'Microsoft Dynamics AX 2012 Development Cookbook' Blog bot DAX Blogs 1 12.05.2012 16:55
dynamics-ax: Interview with Microsoft's Lachlan Cash on his new role, AX 2012 and more Blog bot DAX Blogs 6 22.04.2011 14:55
Часовой пояс GMT +3, время: 14:56.
