Старый 05.03.2014, 17:11   #1
Dynamics AX Sustained Engineering: Making automatic user provisioning for forms-based authentication work
Источник: http://blogs.technet.com/b/dynamicsa...tion-work.aspx
This blog post will help identify and resolve common problems related to making automatic user provisioning for forms-based authentication work for Ax2012R2.
Environment: Environment is assumed to look something like this:
  • One intranet-facing Enterprise Portal using integrated Windows authentication, configured as the default Enterprise Portal in AX
  • One internet-facing claims-aware Enterprise Portal using Forms authentication, set up using the instructions on http://technet.microsoft.com/en-us/library/hh575253.aspx
  • The User request workflow contains the automated task Automated provision user
When creating a new vendor request, from System administration > Common > Users > User requests, there several things can go wrong without additional environment configuration.
Issues and resolutions
Invalid attempt to call sysEPWebPageDefinition.getDevelopmentSite
In AX2012R2, the task Automated provision user will fail with the following error:
Stopped (error): Stack trace: Invalid attempt to call sysEPWebPageDefinition.getDevelopmentSite running in CIL on the client.
Opening the class sysEPWebPageDefinition in the development environment gives the answer pretty quickly:
This class is only possible to invoke from a client – but the workflow runs in server context.
Changing this property to the default value Called from resolves this particular error.
SoapException
In AX2012R2, after correcting the class metadata, the Automated provision user task still does not work. Submitting a user request yields the following error:
Stopped (error): Exception of type 'Microsoft.SharePoint.SoapServer.SoapServerException' was thrown.
A SoapException is a very generic exception with little useful information. If the Sharepoint trace logging level is Medium or higher, a more useful error message can be spotted in the Sharepoint logs:
SOAP exception: System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.Configuration.Provider.ProviderException: The connection name 'FormsDB' was not found in the applications configuration or the connection string is empty.
This exception is thrown from a service, EPDeploymentService, which is invoked on the default Enterprise Portal site, because it is missing a connection string to the ASP.NET database. The default Enterprise Portal does not need to support forms authentication, but in order to create new users it needs to know what database to update.
Configuring the connection string
The connection string needed is actually already configured – but not for any of the Enterprise Portal instances, it is configured only for the forms-based authentication provider. To resolve the problem, this connection string needs to be configured for the default Enterprise Portal as well.
The connection string can be found in the web.config file for the STS, which is typically located in %CommonProgramFiles%\microsoft shared\Web Server Extensions\14\TEMPLATE\LAYOUTS\FormsSTSTemplate
The section should look like this:
Adding the above section to the web.config for the default Enterprise Portal can be done with the Sharepoint Management Shell:
$Section = New-Object Microsoft.SharePoint.Administration.SPWebConfigModification
$Section.Path = "/configuration"
$Section.Name = "connectionStrings"
$Section.Sequence = 0
$Section.Owner = "Connection string for ASP.NET DB"
$Section.Type = [Microsoft.SharePoint.Administration.SPWebConfigModification+SPWebConfigModificationType]::EnsureSection
$Mod = New-Object Microsoft.SharePoint.Administration.SPWebConfigModification
$Mod.Path = "/configuration/connectionStrings"
$Mod.Name = "add[@name='FormsDB']"
$Mod.Sequence = 1
$Mod.Owner = "Connection string for ASP.NET DB"
$Mod.Value = ''
$Mod.Type = [Microsoft.SharePoint.Administration.SPWebConfigModification+SPWebConfigModificationType]::EnsureChildNode
$WebApp = Get-SPWebApplication "http://SharepointServer:Port/"
$WebApp.WebConfigModifications.Add($Section)
$WebApp.WebConfigModifications.Add($Mod)
$WebApp.Update()
$WebApp.Parent.ApplyWebConfigModifications()
Replace the URL http://SharepointServer:Port/ with the URL for the web application that hosts the default Enterprise Portal. If a custom connection string was used when setting up the ASP.NET database, that value will be present in the configuration file instead of the default value used here. If this is the case, enter the custom connection string in setting the property $Mod.Value.
After updating the configuration, the User request workflow will execute without errors.
Other caveats
Because the workflow executes a service on the default Enterprise Portal, there are a few other things that can go wrong.
The workflow might stop with one or more of the following errors:
Stopped (error): The request failed with HTTP status 401: Unauthorized.
This happens because the AOS runs as a service account and is therefore not allowed to access the Sharepoint site. Granting the service account read access to the Sharepoint web application that hosts the default Enterprise Portal will resolve this error.
Stopped (error): Server was unable to process request. ---> Object reference not set to an instance of an object.
In this case, the Application event log holds the key to figuring out this error. From the event source, Microsoft Dynamics AX Enterprise Portal,there should be a message like this:
The log on attempt to the server from user [AOS Service Account] failed, when using Dynamics Adapter LogonAs from process w3wp and thread id 37.
Microsoft.Dynamics.AX.ManagedInterop.LogonFailedException
at Microsoft.Dynamics.AX.ManagedInterop.Session.LogonAs(String user, String domain, NetworkCredential bcProxyCredentials, String company, String language, String objectServer, String configuration, String tenant)
at Microsoft.Dynamics.Framework.BusinessConnector.Session.DynamicsAdapter.LogonAs(String user, String domain, NetworkCredential bcProxyCredentials, String company, String language, String objectServer, String configuration, String partitionKey)
The workflow tried to invoke the web service but the user it executed as did not exist in AX. To resolve this, the AOS service account must exist as a user in AX with role System Administrator. (Please note that if the service account does not have the System Administrator role, the workflow will still fail with an object reference exception but no useful error message will be logged.)
Resolution summary
Enabling automated user provisioning for forms-based authentication requires the following environment modifications:
  • The connection string to the ASP.NET database must be added to the web.config for the default Enterprise Portal
  • The service account the AOS runs as must exist as an AX user with System administrator role
  • For AX2012R2, the property RunOn on class sysEPWebPageDefinition must be changed to Called from
Dynamics AX Sustained Engineering: Announcing Cumulative Update 5 for Microsoft Dynamics AX 2012 & Microsoft Dynamics AX 2012 Feature Pack 1 Blog bot DAX Blogs 0 30.04.2013 01:13
Dynamics AX Sustained Engineering: Announcing Compatibility Certification of SQL Server 2012 SP1 with Dynamics AX 2012 Blog bot DAX Blogs 0 20.02.2013 04:27
Dynamics AX Sustained Engineering: Announcing Compatibility Certification of SQL Server 2008 SP2 with Dynamics AX Blog bot DAX Blogs 0 18.05.2011 05:16
dynamics-ax: Official Details about Dynamics AX '6' released, including comments from Microsofts Kees Hertogh Blog bot DAX Blogs 0 11.01.2011 05:22
Часовой пояс GMT +3, время: 19:56.
