Старый 09.04.2014, 21:12   #1
sashanazarov: Sales invoices in batch: performance issue solved
Источник: http://sashanazarov.blogspot.com/201...rformance.html
Our customer experienced huge performance problems with posting sales invoices in batch.
Teh customer had multiple recurring batch jobs run in their headquarter company. Each batch job processed intercompany sales orders corresponding to a particular regional office. They put the jobs to different batch groups and allocated separate AOSes for those groups.
At some point, the code in production has changed, but the batch jobs have never been recreated. It looks like version of their parameters became outdated and therefore the ranges were ignored at run time, and that resulted in all jobs trying to post all invoices. After their AX admin recreated the recurring jobs, the issue has gone.
So next time you are incrementing CurrentVersion macro in a RunBaseBatch ancestor, consider handling the old version in the unpack-method, so only new parameters will be nil after unpacking.
dynamicsaxtraining: Sales Blog bot DAX Blogs 0 25.04.2012 03:18
axinthefield: Optimizing AX Batch Performance - Batch Group Configuration Blog bot DAX Blogs 0 01.04.2011 13:11
Dynamics AX Sustained Engineering: Sale Order Batch Invoicing reprints invoices from prior runs, when “Print” is set to ‘After’ on AR >> Periodic >> Sales Update >> Invoice form Blog bot DAX Blogs 0 24.03.2010 02:06
axaptapedia: Batch processing Blog bot DAX Blogs 0 29.01.2009 17:05
Часовой пояс GMT +3, время: 05:15.
