Старый 03.05.2014, 05:12   #1
dynamicscpm: How to tell what update of Management Reporter you are using
Источник: http://blogs.msdn.com/b/dynamics_fin...are-using.aspx
If you've ever talked with the support team or the product team, you've probably gotten asked what release of Management Reporter you are using. Here's a quick way to know that update you have on your system.
Go to Help | About in Report Designer:
In the screen shot above, you'll see the version number is 2.1.8000.1. The number 8 in the version number means I'm using Management Reporter 2012 CU8 (Cumulative Update 8). This numbering scheme was added in CU6, so if you see a number like 2.1.1037, that means you are on an update older than CU6.
You can also find the version information in the web viewer by going to Settings | About.
Now that you know what release you are using, you can check out this post to see what features were added in it and other releases.
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 14 Blog bot Dynamics CRM: Blogs 0 12.07.2013 07:13
dynamicscpm: How can you get Management Reporter 2012? Blog bot DAX Blogs 0 11.04.2012 18:11
Часовой пояс GMT +3, время: 16:29.
