Старый 31.12.2014, 01:16   #1
Batch task progress on server for AX 2009
Источник: http://alexvoy.blogspot.com/2014/12/...er-for-ax.html
I already explained how to update progress for batch tasking in AX 2012. Now, it's time for AX2009.
You can simply change new() method in SysOperationProgressServer class as follows:
public void new(int _numberOfBars = 1, boolean _bypass=false)
Evidently it will increase the total execution time of a batch because SysProgress table will be updated for every task as many times as you call incCount(), setCount() etc.
So, it is worth changing construct method in RunbaseProgress class, so that the developer could decide to update progress or not.
Happy New Year!
daxdilip: How to Debug Batch Jobs running on Dynamics AX 2009 with AOS Server on Windows Server 2008 Blog bot DAX Blogs 0 15.12.2010 17:11
Fred Shen: New server-based batch framework in AX 2009 Blog bot DAX Blogs 0 04.05.2009 14:05
Часовой пояс GMT +3, время: 23:38.
