Старый 19.01.2015, 18:11   #1
crminthefield: The Dangers of Guid.NewGuid();
Источник: http://blogs.msdn.com/b/crminthefiel...d-newguid.aspx
Microsoft Dynamics CRM uses GUIDs as their primary key for the entity’s SQL table. Using GUIDs as a primary key is usually not the best item due the random sequence of numbers and letters. The Dynamics platform has an algorithm that generates GUIDs...(read more)
crminthefield: Walkthrough: Easily locate objects in ActiveDirectory by Guid Blog bot Dynamics CRM: Blogs 0 11.02.2012 01:11
East Ocean - Technical: Interesting Tips: Guid without dash Blog bot Dynamics CRM: Blogs 0 27.12.2011 15:11
crminthefield: Microsoft Dynamics CRM 4.0 and 2011 Update Rollup Release Dates, Build Numbers, and Collateral Blog bot Dynamics CRM: Blogs 0 24.08.2011 02:11
crminthefield: Displaying the GUID of the record selected using the parameter Blog bot Dynamics CRM: Blogs 0 05.08.2011 07:12
kamalblogs: Using GUID as primary key in Dynamics Ax Blog bot DAX Blogs 6 05.01.2011 12:19
Часовой пояс GMT +3, время: 08:13.
