Старый 26.02.2015, 18:11   #1
emeadaxsupport: How to select all the records from a grid
Источник: http://blogs.msdn.com/b/axsupport/ar...om-a-grid.aspx
In Microsoft Dynamics AX 2012 not all the records are loaded when a form is opened.
If a user tries to select all the records using Control + A, going to File > Edit > Select all, or selecting the checkbox left to the grid header, they will actually select only the records that are already loaded.
A way to have all the records loaded and selected is to press simultaneously Control + Shift + End.
A message is displayed, informing the user that all records will be loaded and warning the user that it may take a long time:
I hope this is helpful!
Bertrand
With the help of Ankur Kumar.
workflowax: How do I select from table Common in AX? Blog bot DAX Blogs 0 16.11.2011 15:11
emeadaxsupport: How to delete orphaned data remained from deleted company? Blog bot DAX Blogs 0 09.12.2010 16:11
Часовой пояс GMT +3, время: 20:12.
