Старый 13.03.2015, 22:13   #1
emeadaxsupport: You may get message “Failed to create a session; confirm that the user has the proper privileges to log on to Microsoft Dynamics” during an upgrade or in-place upgrade with Microsoft Dynamics AX 2012
Источник: http://blogs.msdn.com/b/axsupport/ar...s-ax-2012.aspx
This error message can be a little misleading as it implies that it is related to some security permissions not being configured correctly. In some cases this can be the case, however it can also be a problem with running CIL code. This can especially occur when you are going through the code upgrade steps.
There are a couple of solutions for this.
  1. Try to complete a full CIL compile with errors.
  2. If the full CIL fails or has errors, then uncheck the “Execute business operations in CIL”, under File > Tools > Options – in the Development tab, as below:
emeadaxsupport: Get started with AX 2012 R3! Blog bot DAX Blogs 0 05.05.2014 09:11
emeadaxsupport: Final Microsoft Dynamics AX 2012 R2 Content Available! Blog bot DAX Blogs 0 04.12.2012 06:12
Sample Design Patterns: Book Give-away: 'Microsoft Dynamics AX 2012 Development Cookbook' Blog bot DAX Blogs 1 12.05.2012 16:55
emeadaxsupport: Microsoft Dynamics AX 2012 Upgrade - Using the State Transfer Tool Blog bot DAX Blogs 0 28.01.2012 02:16
dynamics-ax: Modeling the world, with Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 25.01.2011 09:11
Часовой пояс GMT +3, время: 01:31.
