Старый 12.10.2015, 17:11   #1
emeadaxsupport: Belgian EUSalesList xml file missing the sending company's contact information
Источник: http://blogs.msdn.com/b/axsupport/ar...formation.aspx
If you viewing XML file created by AX to report the EU Sales to Belgian
authorities and experience that the XML file doesn’t
include the company's contact information such as the user's email and Phone number in
the xml file header. This information is mandatory on the INTERVAT website and without
this information the XML file generated file will be rejected.
We have released KB3003995 “Company electronic address
is not marked as IsPrimary for the location when creating a new company”. But
if the “New” legal entity have been created before the KB or the KB isn’t installed
you may check and update this manually.
This issue happens because while generting EUsalesReporting, system uses the
AXDEUSLReporting query. In query for dirpartylocation datasource and to this
datasource, records are filtered based on condition Isprimary. But for new
created Legal entities and while creating electronic address for these new
legal entity- Isprimary is never marked as true, so because of ElectronicAddress
not being marked as primary in DirpartyLocation, so Dirpartylocation record
related to electronic Address is not being fetched and hence Contact
Information is not reflecting on the EUSalesListreport.
And please remember to re-load the EU Sales list XSLT document after HF update.
If the company is already created and in use you may need to fix this
manually….
Please validate the status of the tick box IsPrimary in the DirPartyLocation
table? Which address RECID can be found in LogisticsElectronicAddress.
If you have this issue would expect that in that case this box in
DirPartyLocation table will be blank so as a work around I suggest to mark it
and save and rerun the EU Sales list and the info will be there.
emeadaxsupport: DIXF - Importing Data - How to establish which rows you need to look at when you aren't able to import every row in your input file Blog bot DAX Blogs 0 08.10.2015 15:11
emeadaxsupport: How to perform foreign currency revaluation in Consolidation company to satisfy reporting requirements Blog bot DAX Blogs 0 16.10.2012 22:11
emeadaxsupport: AIF XML file generator Blog bot DAX Blogs 0 20.03.2012 00:12
dynamicsaxtraining: Basic concepts Blog bot DAX Blogs 0 24.02.2012 07:12
crminthefield: Microsoft Dynamics CRM 2011 Custom Contact Entry Website using Early-Bound entity Classes. Blog bot Dynamics CRM: Blogs 0 04.06.2011 08:16
Часовой пояс GMT +3, время: 20:08.
