Старый 25.10.2015, 15:16   #1
Finally, at Van Dijk, we started to get our NAV (Dynamics everyone here is calling it) installation upgraded to the latest version. So finally I can really get into things like PowerShell, and not in the least the merge utilities. One of first things I definitely wanted to get going with.
And surely, as many, I could profit from the various resources on the Internet. Using the scripts from the product DVD, and both Bas Graaf post on the NAV team blog and waldo’s post, I created the PowerShelll script, that allowed me to upgrade our code to NAV 2016. Coming from NAV 2009 R2, this is quite a step, but indeed the merge utilities do a pretty usable job. I really like the way conflicting code is handled. I also ran into some issues where properties are not handled right, but altogether I am really positive.
One other thing I ran into was the handling of the Version List. It’s no secret that this was not properly implemented in theMerge-NAVApplicationObject cmdlet. However, Microsoft provided us some examples by means of aHow do I video and ablog post both by Bas Graaf. And alsowaldo gave a helping hand. I tried both and decided to use Bas Graaf’s solution, called New-NavVersionList. Simply because I got it working somewhat easier and liked it better as it contains lesser lines of code.
But … I found it had one relevant issue: it did not handle the deletion of an version list part. More specifically: between NAV 2009 R2 and NAV 2016 some standard objects, localized for NL, were reverted to w1. Therefor the Version List should, after the merge and post processing with Bas' script, not have a NAVNL part in the Version List. And as you might have guessed, this went wrong.
To get a clear view on the result of the script I setup the following cases:
  • Cases 1 to 6 concerns updated w1 objects existing in NAV 2009 R2 (pure w1, or w1 localized and/or customized)
  • Case 7 a new w1 object
  • Cases 8 and 9 updated local objects (of which one is localized)
  • Case 10 a pure custom object
Guess I covered all options with this.
W1
Local
Object
Object Type
Updated
New
Updated
Removed
Custom
1
COD3
W1
X
2
COD11
W1
X
X
3
COD2
W1
X
X
X
4
COD74
W1
X
X
5
COD12
W1
X
X
6
COD1
W1
X
X
X
7
COD19
W1
X
8
COD11401
Local
X
9
COD11400
Local
X
X
10
COD50000
Custom
X
Running the Merge-NAVApplicationObject cmdlet and post processing it with the original New-NavVersionList the result was as follows:
Object
Status
Original
Modified
Target
Result
Expected Result
1
COD3
OK
NAVW14.00
NAVW19.00
NAVW14.00
NAVW19.00
NAVW19.00
2
COD11
OK
NAVW16.00.01, NAVNL5.00
NAVW19.00, NAVNL9.00
NAVW16.00.01,NAVNL5.00
NAVW19.00,NAVNL9.00
NAVW19.00,NAVNL9.00
3
COD2
OK
NAVW16.00.01, NAVNL4.00.01
NAVW16.00.01,NAVNL4.00.01, CUSTOM6.00
NAVW19.00,NAVNL9.00, CUSTOM6.00
4
COD74
OK
NAVW14.00.01
NAVW18.00
NAVW14.00.01,CUSTOM6.22
NAVW18.00,CUSTOM6.22
5
COD12
NOT OK
NAVW16.00.10, NAVNL5.00
NAVW19.00
NAVW16.00.10,NAVNL5.00
NAVW19.00,NAVNL5.00
NAVW19.00
6
COD1
NOT OK
NAVW19.00
NAVW16.00.10,NAVNL5.00, CUSTOM6.39
NAVW19.00,NAVNL5.00, CUSTOM6.39
NAVW19.00,CUSTOM6.39
7
COD19
OK
NAVW19.00
NAVW19.00
NAVW19.00
8
COD11401
OK
NAVNL6.00.01
NAVNL8.00
NAVNL6.00.01
NAVNL8.00
NAVNL8.00
9
COD11400
OK
NAVNL6.00
NAVNL8.00
NAVNL6.00,CUSTOM6.25
NAVNL8.00,CUSTOM6.25
10
COD50000
OK
CUSTOM3.0
CUSTOM3.0
CUSTOM3.0
As you can see case 5 and 6 where not OK (have a look at the Result andExpected Result), being the fact that the NAVNL should not end up in theResult as the NL localization was removed from both COD 1 and COD12 (have also a look at the Modified and Target).
For clarity this was the merge scenario:
ORIGINAL = NAV 2009 R2
MODIFIED =NAV 2016
TARGET =CUSTOM NAV 2009 R2
RESULT = CUSTOM NAV 2016
For completeness I also executed the other, valid scenario:
MODIFIED =CUSTOM NAV 2009 R2
TARGET =NAV 2016
Resulting in:
Object
Status
Original
Modified
Target
Result
Expected Result
11
COD3
OK
NAVW14.00
NAVW14.00
NAVW19.00
NAVW19.00
NAVW19.00
12
COD11
OK
NAVW19.00,NAVNL9.00
NAVW19.00,NAVNL9.00
13
COD2
OK
14
COD74
OK
NAVW14.00.01
NAVW18.00
15
COD12
OK
NAVW19.00
NAVW19.00
NAVW19.00
16
COD1
NOT OK
NAVW19.00
17
COD19
OK
NAVW19.00
NAVW19.00
NAVW19.00
18
COD11401
OK
NAVNL6.00.01
NAVNL6.00.01
NAVNL8.00
NAVNL8.00
NAVNL8.00
19
COD11400
OK
NAVNL6.00
NAVNL8.00
20
COD50000
OK
CUSTOM3.0
CUSTOM3.0
CUSTOM3.0
Being still an amateur PowerShell user I tried to tweak the script to get the desired result, but, honestly, I totally failed, and asked Bas for help, who quite quickly answered with an improved version. Well … a changed version that yielded the same results. But his second improvement was a hit.
Original Script
functionNew-NavVersionList($MergeInfo,[string[]]$ProductCode= ("NAVW1","NAVNL","CUSTOM"))
$allVersions= @() +$MergeInfo.modified.versionlist-split ‘,’
$allVersions+= $mergeInfo.target.versionlist-split ‘,’
$mergedVersions= @()
foreach ($code in$ProductCode)
# keep the “highest” version tag for $code
$mergedVersions+= $allVersions| where {$_ -like“$code*” } | sort| select-last 1
# remove all $code version tags
$allVersions= $allVersions| where {$_ -notlike“$code*” }
# return a ,-delimited string consisting of the “highest” versions for each $ProductCode and any other tags
$mergedVersions-join ‘,’
Improved Script
# add only to merged version list if the product code was not removed
if (($MergeInfo.original.versionlist-notlike "*$code*"-or ($allVersions-like "$code*").Count-ge 2))
The main part of the script was left unchanged, only an if-clause was added that incorporates the code to select the “highest” version tag.
Facit
Now it work perfectly well in all cases I am working with. As you can see I did not test it with more than three tags in the Version List. I leave that up to you.
A big thanx to Bas Graaf!
Читать дальше
Часовой пояс GMT +3, время: 14:56.
