Старый 20.01.2016, 22:13   #1
emeadaxsupport: DIXF – AX 2012 R3 KB3061216 – Support for new DIXF entities
Источник: https://blogs.msdn.microsoft.com/axs...dixf-entities/
We released a useful DIXF Application Hotfix in October 2015 which you may not be familiar with, and as I’ve recently been looking into this for a customer, I thought I would share some details on this topic. If you are running AX 2012 R3, then you can install KB3061216 and add a large number... Read more
emeadaxsupport: How to install and set up integration with MS Project in AX 2012 R3 successfully the first time Blog bot DAX Blogs 0 25.09.2015 19:14
emeadaxsupport: Warning when installing AX 2012 R3 Application hotfix: The model store you selected requires a newer version of the installer than the one you're using. Blog bot DAX Blogs 0 03.09.2015 15:11
axsa: MDM Adapter - Extending Dynamics AX 2012 R3 Master Data Management Blog bot DAX Blogs 0 22.05.2014 03:28
emeadaxsupport: AX Content: Management Packs for AX 2012 R3! Blog bot DAX Blogs 0 20.05.2014 04:28
Часовой пояс GMT +3, время: 06:52.
