Старый 28.03.2016, 22:12   #1
organicax: Reuse configurations on constraint based product model
Источник: http://organicax.com/2016/03/28/reus...product-model/
If you are using the constraint based product configurator then you might want to consider the overall lifecycle of the data in your system. There is an option to enable reuse of configurations which will avoid creating a new BOMs for example. This is helpful if customers want similar configurations to other customers then you can choose to let the system search for existing configurations instead of creating new ones an avoiding the proliferation of data in the system.
Here is a quick look.
AX2012 R3 CU9.
If you want to have a look at the setup of the simple model that was used you can see the setup in this post.
Cheers
Lachlan
Filed under: Product information management
dynamics-coe: Override configuration ID in the constraint-based product configurator in AX2012 Blog bot DAX Blogs 0 29.04.2015 11:11
axmfg: Product Configuration: Setting values based on system variables - example, current user ID Blog bot DAX Blogs 0 29.04.2014 20:11
axmfg: Attribute based sales prices for the Product configurator Blog bot DAX Blogs 0 05.11.2013 15:11
axmfg: Understanding the default configuration concept for constraint-based products Blog bot DAX Blogs 0 17.07.2013 14:11
DynamicsAxSCM: Product-item data management services Blog bot DAX Blogs 0 06.07.2011 17:11
Часовой пояс GMT +3, время: 18:14.
