Старый 11.04.2016, 19:12   #1
organicax: AR Parameters – Fulfillment rate, Fulfillment violation messages
Источник: https://organicax.com/2016/04/11/ar-...tion-messages/
In a previous post we had a look at partial shipments. If you are using release to warehouse from the sales order and you want to control fulfillment rates then you can have a look at the accounts receivable parameters for the company wide setting or on the customer settings for a specific customer control.
There are 3 parameters called fulfillment rate, Value type, Fulfillment violation messages which you will fine on the AR parameters and customer. Fulfillment rate for example if you set at 100 will allow you to control that the full quantity is handled. The value type can be set to price and quantity. Usually this will probably used at quantity, but could be set to price. Violation messages setting will allow you to control if the users is just shown a warning or and error to stop them releasing if it’s below the fulfillment rate.
Here is a quick overview.
AX2012 R3 CU9
Cheers
Lachlan
Filed under: Accounts receivable, Sales and marketing, Warehouse management
organicax: AR Parameters – Period of validity Blog bot DAX Blogs 0 05.04.2016 11:11
organicax: Warehouse mobile device text colors some additional notes on setup Blog bot DAX Blogs 0 25.03.2016 12:11
dynamicsax-fico: Effective labor rate Blog bot DAX Blogs 0 23.02.2016 15:11
emeadaxsupport: How to populate the Vehicle Type field in the Worker Mileage Rate form Blog bot DAX Blogs 0 31.03.2015 21:12
emeadaxsupport: "An exchange rate cannot be found for exchange rate type XXX between currencies YYY and ZZZ on exchange date." when you attempt to process in Microsoft Dynamics AX 2012 Blog bot DAX Blogs 0 26.09.2012 07:15
Часовой пояс GMT +3, время: 06:07.
