Старый 29.05.2008, 21:11   #1
B
в†ђOlder revision
Revision as of 17:11, 29 May 2008
Line 21:
Line 21:
==B== ==B==
{{top}} {{top}}
+'''[[Backup]] - a data set which is not a complete copy of the system (e.g. [[NAV database]]) but contains enough information to rebuilt it.
'''[[The Beauty Of Simplicity|Beauty Of Simplicity, The]]''' - Original [[PC&C]] catch phrase for Navision. '''[[The Beauty Of Simplicity|Beauty Of Simplicity, The]]''' - Original [[PC&C]] catch phrase for Navision.
Line 179:
Line 181:
'''[[Single instance codeunit]]''' - when run will create only one instance of it self on the client. That means that any other function that calls a Single Instance CodeUnit will see the same variables and data as any other task. '''[[Single instance codeunit]]''' - when run will create only one instance of it self on the client. That means that any other function that calls a Single Instance CodeUnit will see the same variables and data as any other task.
+'''[[Session]]''' - a connection between a [[Client]] and the [[Server]]. Sessions are counted as the number of client currently attached to the server.
'''[[NAV_version_history#Product_Names|Solutions]]''' - Version 3.00 was initially given the name Navision Solutions. '''[[NAV_version_history#Product_Names|Solutions]]''' - Version 3.00 was initially given the name Navision Solutions.
Источник http://wiki.dynamicsbook.com/index.p...e=NAV_glossary
Старый 30.05.2008, 10:42   #2
apanko is offline
apanko
1,164 / 139 (7) +++++
Кто-нибудь в живую видел C/DART (упоминался по ссылке выше)?
Часовой пояс GMT +3, время: 11:48.
