Старый 03.04.2009, 22:33   #1
With the release of 5.0 SP1, a new data type conversion routine was introduced with codeunit 5302 - Outlook Synch. Type Conversion. There are several known issues with data migration due to these changes.
The previously published blog for 5.0 SP1 contains a change log of some code suggestions and workarounds for the more common and/or critical issues.
This blog addresses many of the same issues in NAV 2009. While some corrections were made between the release of 5.0 SP1 and 2009, not all fixes made it into the RTM release of 2009. The following change log can be applied to the 2009 objects.
This change log applies to 2009 RTM application objects ONLY.
Issues addressed by the change log:
1) Overflow on type conversion from Text to Text in Form 8626 when a text field larger than 100 chars is imported.
2) Error on import of fields beginning with a number -1099 Code, etc.- The call to member selectSingleNode failed. msxml6.dll returned the
following message: Expression must evaluate to a node-set.
3) Imported dates are blank after migration data is applied.
4) Negative decimal values are converted incorrectly, resulting in changed values.
5) Expected token 'EOF' found '$'. Error on fields with $ symbol
Changes are labeled with the associated number above.
Form 8626 Migration Records
Before:
CODE
VAR
MatrixColumnCaptions@1000 : ARRAY [100] OF Text[100];
MigrationData@1001 : Record 8615;
MatrixCellData@1002 : ARRAY [100] OF Text[100];
MigrationColumnField@1004 : ARRAY [100] OF Integer;
MatrixColumnOrdinal@1003 : Integer;
FormCaption@1005 : Text[1024];
TableNo@1006 : Integer;
Text001@1007 : TextConst 'ENU=%1 value ''%2'' does not exist.';
After:
CODE
VAR
MatrixCellData@1002 : ARRAY [100] OF Text[250]; // changed #1 - changed from Text[100] to Text[250]
* XMLport 8610 - Setup DataSchema
NameIn := DELCHR(NameIn,'=','Г™''`');
NameIn := DELCHR(CONVERTSTR(NameIn,'<>,./+-&()%',' '),'=',' ');
NameIn := DELCHR(NameIn,'=',' ');
EXIT(NameIn);
After:
NameIn := DELCHR(CONVERTSTR(NameIn,'<>,./+-&()%$',' '),'=',' '); // Changed - added $ symbol and one additional space between single quotes #5
IF (NameIn[1] >= '0') AND (NameIn[1] <= '9') THEN // Added #2
NameIn := '_' + NameIn; // Added #2
EXIT(NameIn);
* Codeunit 8611Function FieldNodeExists ...
Before:
FieldNode := RecordNode.selectSingleNode(FieldNodeName);
IF NOT ISCLEAR(FieldNode) THEN
EXIT(TRUE);
After:
IF (FieldNodeName[1] >= '0') AND (FieldNodeName[1] <= '9') THEN // Added #2
FieldNodeName := '_' + FieldNodeName; // Added #2
EXIT(TRUE);
* Codeunit 8611, Function GetElementName
Before:
EXIT(NameIn);
After:
NameIn := DELCHR(CONVERTSTR(NameIn,'<>,./+-&()%$',' '),'=',' '); //Changed - added $ symbol and one additional space between single quotes #5
EXIT(NameIn);
* Codeunit 8611, Function InsertRecordWithKeyFields
Before:
VAR
MatrixData@1001 : Record 8615;
MigrationTableField@1007 : Record 8616;
OSynchTypeConversion@1008 : Codeunit 5302;
RecRef1@1006 : RecordRef;
KeyRef@1003 : KeyRef;
FieldRef@1004 : FieldRef;
KeyFieldCount@1005 : Integer;
ToValidate@1009 : Boolean;
BEGIN
MatrixData.SETRANGE(TableID,MatrixRecord.TableID);
MatrixData.SETRANGE("No.",MatrixRecord."No.");
KeyRef := RecRef.KEYINDEX(1);
FOR KeyFieldCount := 1 TO KeyRef.FIELDCOUNT DO BEGIN
FieldRef := KeyRef.FIELDINDEX(KeyFieldCount);
ValidationFieldID := FieldRef.NUMBER;
MatrixData.SETRANGE(FieldID,FieldRef.NUMBER);
IF MatrixData.FIND('-') THEN BEGIN
MigrationTableField.GET(MatrixData.TableID,MatrixData.FieldID);
ToValidate := MigrationTableField.Validate AND NOT TestRelation(FieldRef);
OSynchTypeConversion.EvaluateTextToFieldRef(MatrixData.Value,FieldRef,ToValidate
END ELSE
IF KeyRef.FIELDCOUNT <> 1 THEN BEGIN
ERROR(STRSUBSTNO(Text000,FieldRef.NAME,RecRef.NAME + ':' + FORMAT(MatrixData."No.")));
END
END;
RecRef1 := RecRef.DUPLICATE;
IF RecRef1.FIND('=') THEN BEGIN
RecRef := RecRef1;
EXIT
END;
RecRef.INSERT(NOT CompanySetupRun);
END;
After:
VAR
Field@1010 : Record 2000000041; // Added #3
Datevalue@1011 : Date; // Added #3
BEGIN
//OSynchTypeConversion.EvaluateTextToFieldRef(MatrixData.Value,FieldRef,ToValidate
); // removed #3
Field.GET(RecRef.NUMBER, FieldRef.NUMBER); // Added #3
IF Field.Type <> Field.Type:ate THEN // Added #3
) // Added #3
ELSE BEGIN // Added #3
EVALUATE(Datevalue, MatrixData.Value); // Added #3
FieldRef.VALUE := Datevalue; // Added #3
END; // Added #3
END ELSE
END
END;
RecRef := RecRef1;
EXIT
END;
END;
* Codeunit 8611, Function ModifyRecordWithOtherFields
Before:
VAR
MatrixData@1002 : Record 8615;
MigrationTableField@1000 : Record 8616;
Question@1003 : Record 8612;
Field@1007 : Record 2000000041;
MigrationTable@1009 : Record 8613;
DataTemplateHeader@1011 : Record 8618;
QuestionnaireMgt@1006 : Codeunit 8610;
TemplateMgt@1012 : Codeunit 8612;
OSynchTypeConversion@1014 : Codeunit 5302;
FieldRef@1001 : FieldRef;
OptionInt@1008 : Integer;
DateFormula@1010 : DateFormula;
ToValidate@1013 : Boolean;
After:
VAR
DateValue@1500000 : Date; // Added #3
Before:
IF MigrationTableField.FIND('-') THEN
IF NOT IsKeyField(MigrationTableField.TableID,MigrationTableField.FieldID) THEN BEGIN
FieldRef := RecRef.FIELD(MatrixData.FieldID);
IF CompanySetupRun THEN
ToValidate:= FALSE
ELSE
END;
IF DataTemplateHeader.GET(MigrationTable."Data Template") THEN
TemplateMgt.UpdateRecord(DataTemplateHeader,RecRef);
After:
ToValidate:= FALSE
ELSE
) // removed #3
) // Added #3
EVALUATE(DateValue, MatrixData.Value); // Added #3
FieldRef.VALUE := DateValue; // Added #3
END; // Added #3
END;
* Codeunit 5302, Function TextToDecimal
Before:
VAR
PartArray@1003 : ARRAY [2] OF Text[250];
IntegeralPart@1001 : Integer;
FractionalPart@1002 : Integer;
After:
VAR
Sign@1005 : Integer; //add new local variable #4
Before:
DecVar := IntegeralPart + (FractionalPart / POWER(10,STRLEN(PartArray[2])));
After:
IF STRPOS(InputText,'-') = 0 THEN //added #4
Sign := 1 //added #4
ELSE //added #4
Sign := -1; //added #4
DecVar := (Sign * (ABS(IntegeralPart) + (FractionalPart / POWER(10,STRLEN(PartArray[2]))))); //changed #4
Laura K. Lake
Microsoft Dynamics NA
Microsoft Customer Service and Support (CSS) North America
These postings are provided "AS IS" with no warranties and confer no rights. You assume all risk for your use.
Читать дальше
Часовой пояс GMT +3, время: 11:38.
