Старый 04.05.2011, 17:11   #1
Jim Wang: Customer Portal 2011 - An error has occurred while loading content required for this feature
Источник: http://jianwang.blogspot.com/2011/05...-occurred.html
It's just a quick post here, hopefully to save your time: if you deploy the Customer Portal for Microsoft Dynamics CRM 2011 on a Windows Server 2008 machine or VM, and get this error message when editing the page: "An error has occurred while loading content required for this feature"
Windows Event log doesn't say anything about it, but if you fiddler it, you will find a 404 error related on a Cms.svc endpoint:
Solution:
To solve this issue, firstly make sure you have installed the WCF activation features.
Also you have installed Windows Server 2008 R2 + SP1 , you need to install the Microsoft .NET Framework 4 KB2468871
Thanks MVP Shan McArthur from Adxstudio to point out on his blog:
Jim Wang: mSketch: Dynamics CRM 2011 Designer's Tool - Using Microsoft Expression Blend with Sketchflow Blog bot Dynamics CRM: Blogs 0 01.04.2011 06:13
Мелкомягкий CRM: Панель управления для MS CRM с помощью Reporting Services Blog bot Dynamics CRM: Blogs 1 24.08.2009 14:41
Microsoft Dynamics CRM Team Blog: Check Out Our New Articles and a New Feature: Add Community Content! Blog bot Dynamics CRM: Blogs 0 31.01.2009 04:12
Часовой пояс GMT +3, время: 02:52.
