Старый 06.01.2014, 19:11   #1
crminthefield: Blank page with no content is displayed when trying to view the Microsoft Dynamics CRM 2013 Implementation Guide (IG) .chm file
Источник: http://blogs.msdn.com/b/crminthefiel...-chm-file.aspx
I recently ran into a problem when trying to view the Microsoft Dynamics CRM 2013 Implementation Guide (IG) .chm file.
I was able to view the contents in the left hand navigation and also search for content, but I was only able to see a blank white screen on the right hand side. This is because of a built in Windows security feature that's implemented on certain file types downloaded from the Internet. This KB article has more details on this security feature.
I ran into a similar security problem with the CRM 2011 Implementation Guide, so it was easy to fix, but I know this could be troublesome for others as well. So, I wanted to share this blog post with you in case you run into this issue.
I had to right click and go to the Properties of the .chm file and click Unblock. Then I was able to view the CRM 2013 IG .chm file successfully.
Hope this helps!
Thanks!
Shawn Dieken
Follow the conversation:
@sdieken
@pfedynamics | http://www.pfedynamics.com
Here are the detailed steps to resolve this issue:
1. Navigate to the folder you extracted the Implementation Guide files | Right Click on the .chm file | Select Properties.
2. Select the 'Unblock' button at the bottom of the General tab and then click OK.
You should now be able to view and search the CRM 2013 Implementation Guide chm file successfully.
crminthefield: Podcast and Overview: Microsoft Dynamics CRM 2011 Update Rollup 8 Blog bot Dynamics CRM: Blogs 1 30.04.2016 10:26
Microsoft Dynamics CRM Team Blog: Update Rollup 3 for Microsoft Dynamics CRM 2011 Blog bot Dynamics CRM: Blogs 3 03.08.2011 09:11
crminthefield: Overview: Microsoft Dynamics CRM 4.0 Update Rollup 18 Blog bot Dynamics CRM: Blogs 0 01.07.2011 02:12
Часовой пояс GMT +3, время: 08:11.
